High voltage readings
This radio is the console type and one of the two speakers was missing. I replaced it with a modern speaker and inserted an appropriately sized resistor to make up for the missing field coil. I'm guessing that the original speakers field coil went bad since there was a speaker installed that hardly had anything left of the cone and did not have the voice coil connected, just the field coil. I also had to replace the audio output transformer and will probably rewind the original next winter.
Both filter caps are 10mfd. The originals had previously been replaced with this size. I recall coming across something that mentioned going from 6mfd to 8mfd and possibly another reference to going up to 10mfd. I decided to go with 10mfd since that is what was installed as a replacement at some time in the past.
Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it.
High voltage readings - by Tom45acp - 05-08-2020, 05:37 PM
RE: High voltage readings - by gregb - 05-08-2020, 05:50 PM
RE: High voltage readings - by Tom45acp - 05-08-2020, 07:17 PM
RE: High voltage readings - by Radioroslyn - 05-08-2020, 08:44 PM
RE: High voltage readings - by Tom45acp - 05-09-2020, 04:00 PM
RE: High voltage readings - by Steve Davis - 05-09-2020, 05:57 PM
RE: High voltage readings - by morzh - 05-09-2020, 06:31 PM
RE: High voltage readings - by Tom45acp - 05-10-2020, 08:29 PM
RE: High voltage readings - by morzh - 05-10-2020, 09:01 PM
RE: High voltage readings - by Tom45acp - 05-11-2020, 08:59 AM
RE: High voltage readings - by morzh - 05-11-2020, 10:42 AM
RE: High voltage readings - by Tom45acp - 05-11-2020, 06:44 PM
RE: High voltage readings - by morzh - 05-11-2020, 08:45 PM
RE: High voltage readings - by Tom45acp - 05-12-2020, 08:44 AM
RE: High voltage readings - by RodB - 05-12-2020, 09:19 AM
RE: High voltage readings - by morzh - 05-12-2020, 10:18 AM
RE: High voltage readings - by Tom45acp - 05-12-2020, 12:12 PM
There are currently 2323 online users. [Complete List]
» 1 Member(s) | 2322 Guest(s)
