Silvertone model 4588A tone / flash tuning issue
Swapped out all tubes one by one again, even trying metal tubes where available all to no change. Then I took some voltage readings today.
1.) 5X4 I get 410VAC across pins 3 & 5 (plates), and 358 DC across pins 7 & 8. Schematic calls for 325 V
2.) 6N6's I get 310 on pin 3, and 325 on pin 4. Show be 280 & 290 respectively
3.) 6C5 Phase Changer I get 174 on pin 3 and 8 on pin 8. Should be 165 and 12 respectively
4.) 6C5 2nd AF I get 182 on pin 3 and 8 on pin 8. Should be 155 and 12 respectively
5.) 6Q7 1st AF I get 172 on pin 3. Should be 110
6.) 6J7 AFC I get 214 on pin 3, 111 on pin 4, and 3 on pin 8. Should be 190, 90, and 4.25 respectively
7.) 6C5 OSC I get 81 on pin 3. Should be 90
8.) 6K7 IF I get 283 on pin 3, 84 on pin 4, 1.2 on pin 5 and 7.2 on pin 8. Should be 255, 110, 4.25, 4.25
9.) 6K7 RF I get 281 on pin 3, 83 on pin 4, 1 on pin 5 and 9.7 on pin 8. Should be 255, 110, 7, 7
10.) 6L7 translator I get 281 on pin 3, 84 pin 4, 0 on pin 5, and 9.7 on pin 8. Should be 255, 110, 7, 7
Voltages are running a bit high in general, and none on pin 5's of the 6K7 RF and 6L7 tubes. I can hear the contacts arcing under the chassis when the set is first turned on. The flash tuning light flickers on and off for about 10-15 seconds then it settles down. Need to try to figure out how to get those contacts apart and see why no voltage appears on pin 5.
