10-22-2020, 10:21 PM
Kirk,
If you are reading this, you are the local turntable expert.
I am overhauling the PE Rex changer for this radio.
First, I cleaned and lubed the motor , so it runs now. Was gummed up.
Not sure you would know the ones below but what if.....
When I took the triangular plate off, I noticed one pin was not held by e-clip, and the grommet did not have the washer on top.. Then I realized it was threaded. No nut.
Then another pin had two washers.
So:
1. Is the threaded pin supposed to have the nut and the washer?
2. What size nut is it. The pins diameters are 3.5mm. Is it M3 or something else?
3. One E retaining clip broke. What size clips are those?
More Qs:
Have the cartridge, no styli. Where do I get those?
What lube do I need for mechanical parts (other than the motor)? Would white Lithium grease do?
Where do I get the belts? They hardened and became drop-shaped. Are there PRB or other belts for it?
So:
More Qs:
