Philco 38-14 Radio Tube Compatibility and Sources
Hi Meghan and welcome,
As Mike said as long as they have the proper numbers your OK. You could do a very cursory test by using an ohm meter by measuring the resistance between the to fat pins on the base of each tube. What that will tell you is if the heater inside the tube is good. The heater is the part that glows when the set is on. If the heater is bad then the tube is likewise. So you should see several ohms between the two pins.
GL with your project!
Now I think I've got it!
RE: Philco 38-14 Radio Tube Compatibility and Sources - by Radioroslyn - 11-19-2020, 04:17 PM
Tube Compatibility - by Inkthinker2 - 11-19-2020, 04:36 PM
Electrolytic, Film Caps, Isotap - by Inkthinker2 - 12-16-2020, 11:14 PM
Great Information - by Inkthinker2 - 12-17-2020, 01:43 PM
There are currently 1557 online users. [Complete List]
» 4 Member(s) | 1553 Guest(s)
AvatarAvatarAvatarAvatar
