Peerless Radio Find
Today I changed the first filter cap from 450uf to 33uf this should lower the peak rectifier current.  Then redrew the power supply so it made sense.
 I also drew in the ground at the 6A7 cathode where it use to have the volume control attached to it.
I also decided that it had too much audio gain after changing the 76 tube from detector to audio amp.  and added some resistors to the volume control. I know I could have added a resistor the the 76 cathode and may try this instead.
 After looking closer at the power supply I moved the power switch to hot side of the cord with a 2 amp fuse and made sure the neutral side went to the chassis part of the bias circuit. (it's a polarized plug) Now I only have 10vac from the chassis to earth ground.
Peerless Radio Find - by OZ4 - 05-08-2017, 01:17 PM
RE: Peerless Radio Find - by WallaceRoger - 05-08-2017, 02:56 PM
RE: Peerless Radio Find - by WallaceRoger - 05-08-2017, 03:11 PM
RE: Peerless Radio Find - by OZ4 - 05-08-2017, 03:45 PM
RE: Peerless Radio Find - by Mondial - 05-08-2017, 04:06 PM
RE: Peerless Radio Find - by OZ4 - 05-08-2017, 04:36 PM
RE: Peerless Radio Find - by palegreenthumb - 05-12-2017, 03:07 AM
RE: Peerless Radio Find - by Arran - 05-15-2017, 12:59 AM
RE: Peerless Radio Find - by OldRestorer - 05-15-2017, 10:18 AM
RE: Peerless Radio Find - by Arran - 05-15-2017, 11:33 PM
RE: Peerless Radio Find - by OldRestorer - 05-16-2017, 09:59 AM
RE: Peerless Radio Find - by klondike98 - 05-17-2017, 11:45 AM
RE: Peerless Radio Find - by morzh - 05-17-2017, 11:51 AM
RE: Peerless Radio Find - by WallaceRoger - 05-17-2017, 01:35 PM
RE: Peerless Radio Find - by OZ4 - 01-08-2021, 01:35 PM
RE: Peerless Radio Find - by morzh - 01-08-2021, 03:10 PM
RE: Peerless Radio Find - by Radioroslyn - 01-08-2021, 03:36 PM
RE: Peerless Radio Find - by OZ4 - 01-08-2021, 10:19 PM
RE: Peerless Radio Find - by Simon Wa3uay - 01-09-2021, 03:02 PM
Peerless Radio Find - by OZ4 - 05-16-2017, 11:34 AM
RE: Peerless Radio Find - by OZ4 - 05-17-2017, 11:07 AM
