Model 90 1st RF question
I had a similar problem with model 370 (model 70 chassis) It has the same style coil. Mine had a broken wire and I was able to resolder it. In your case If the continuity check ok than the problem isn't the coil. Would check the plate, screen grid, and cathode voltage of the rf amp tube. While you have the coil out check the resistance of the rf section of the tuning condenser (should measure open with the condenser all the way closed).Rf amp tube ok?
If you really think it is the primary of the coil, take a cardboard tube small enough to fit inside you rf coil and wind 50turns of small gauge magnet wire. With the set all back together take the coil you just made and place it inside the rf coil in the set. Take one of the wires from that coil and hook it to your antenna. It the reception is much better then it is the antenna coil.
Now I think I've got it!
Model 90 1st RF question - by mgutierres - 03-18-2011, 12:26 PM
RE: Model 90 1st RF question - by brett2752 - 01-28-2024, 04:27 PM
RE: Model 90 1st RF question - by Chas - 01-28-2024, 06:51 PM
Re: Model 90 1st RF question - by Ron Ramirez - 03-18-2011, 01:36 PM
Re: Model 90 1st RF question - by 7estatdef - 03-18-2011, 06:18 PM
Re: Model 90 1st RF question - by Steve Davis - 03-19-2011, 07:08 PM
Re: Model 90 1st RF question - by mgutierres - 03-23-2011, 10:01 PM
Re: Model 90 1st RF question - by 7estatdef - 03-24-2011, 02:10 PM
There are currently 1530 online users. [Complete List]
» 2 Member(s) | 1528 Guest(s)
