Phico 38-40 antenna coil
Gary, if I’m understanding this right, your terminal 2 of coil #1 is going to ground according to what you did. Doing that effectively by passes the primary of coil #2. Then terminal 3 of coil #1 is going to the grid of the 6A8G but terminal 4 you say is going to R17, effectively bypassing the secondary of coil #2. In doing that, you have no way of getting a signal from the Ant. terminal to the 6A8G. Coil #1 isn’t there and coil #2 is bypassed so no signal being induced in coil #2. Hopefully if you get a good band selector switch and a coil #1, things will work!
Ron
Philco 37-116.    Philco 70
Philco 52-944.    AK 84
Phico 38-40 antenna coil - by GaryK - 01-22-2021, 08:32 PM
RE: Phico 38-40 antenna coil - by rfeenstra - 01-23-2021, 01:36 AM
RE: Phico 38-40 antenna coil - by GaryK - 01-23-2021, 02:41 PM
RE: Phico 38-40 antenna coil - by radio1 - 01-26-2021, 10:46 PM
RE: Phico 38-40 antenna coil - by rfeenstra - 01-26-2021, 11:46 PM
RE: Phico 38-40 antenna coil - by GaryK - 01-27-2021, 12:31 PM
RE: Phico 38-40 antenna coil - by GaryK - 01-27-2021, 12:41 PM
RE: Phico 38-40 antenna coil - by rfeenstra - 01-27-2021, 01:25 PM
RE: Phico 38-40 antenna coil - by 462ron - 01-28-2021, 08:47 AM
RE: Phico 38-40 antenna coil - by GaryK - 01-28-2021, 10:49 AM
RE: Phico 38-40 antenna coil - by radio1 - 01-28-2021, 07:56 PM
RE: Phico 38-40 antenna coil - by GaryK - 01-28-2021, 11:31 PM
RE: Phico 38-40 antenna coil - by GaryK - 02-10-2021, 03:26 PM
