07-17-2021, 04:57 PM
I did get a small shock when connecting the 9 volt to the two wires coming from the field coil but no click from the speaker. The resistance there was measured at 1.05 K.
I’m confused as to what you mean when you mention the two pins to test the primary transformer. I measured between points from 1-2, 1-3, 1-4, 2-3 etc on the photo and the most I got from any combination was 2.0 ohms. I’m not sure where the two pins I should be measuring from are.
The speaker is not connected to the chassis at this time, should it be?
Thanks for your patience.
