dim bulb tester - Zenith 775B
They are easy enough to construct, the difficulty is in finding incandescent light bulbs. What I did was make an extension cord with a pair of standard electrical outlets, and wired it so the bulb filament was in series with the hot side of the line, then I could plug a table lamp into it. If you do it this way you can use a lamp with a trilight bulb, and switch in the desired wattage in stages, trillight bulbs were exempt from the silly bans.
dim bulb tester - Zenith 775B - by mg34.42 - 12-23-2021, 02:11 AM
RE: dim bulb tester - by GarySP - 12-23-2021, 02:50 AM
RE: dim bulb tester - by mg34.42 - 12-23-2021, 02:52 AM
RE: dim bulb tester - Zenith 775B - by GarySP - 12-23-2021, 09:43 AM
RE: dim bulb tester - Zenith 775B - by GarySP - 12-23-2021, 10:04 AM
RE: dim bulb tester - Zenith 775B - by radiorich - 12-23-2021, 02:17 PM
RE: dim bulb tester - Zenith 775B - by mg34.42 - 12-23-2021, 03:02 PM
RE: dim bulb tester - Zenith 775B - by GarySP - 12-23-2021, 05:25 PM
RE: dim bulb tester - Zenith 775B - by Arran - 12-24-2021, 07:47 PM
