Recapped My Predicta Tandem, I don't know what to do
Threads: 94
City: Annapolis, IL
State, Province, Country: USA
I’m seeing both vertical and video problems. Make sure you put the correct value caps in. +1 on what Bob said on the linearly and height controls. Since you have good sound, that pretty much rules out tuner and IF. Check your video detector diode. Horizontal looks good and i don’t see sync issues. Look from your video detector to your output. Did you check the picture tube? Remember, this may use 2.5v NOT 6v! Don’t blow your filament!! You might post a pic of a video also. Hope this helps some. Oh, some audio output tube circuits are used as a voltage divider, so a problem there can affect other parts of the set.
Tim
RE: Recapped My Predicta Tandem, I don't know what to do - by TV MAN - 01-04-2022, 08:17 PM
| The Philco Parts Catalog for 1942 shows it as usable for 175 kHz, 260 kHz, and 465 kHz. The instructions will show how t...DaleHCook — 11:19 AM |
| Hello Rob,
I agree with you—I have one here at my house that I need to check out. It’s way over-engineered just to make...radiorich — 11:05 AM |
My Atwater Kent 84
| Well getting around to restoring my AK84. Mike was a big part in me being able to snatch this one a few years ago. I won...462ron — 10:57 AM |
| The engine is a B&S 23 inch cast Iron holds 2 quarts of oil. The Generator is a 4 pole 1800 rpm mine was made in 195...David — 10:51 AM |
| Dale: Modified topic as suggested. It is not for a specific project. I found it in a box of stuff I recently purchased...GRG — 10:34 AM |
That looks a lot like an aircraft connector of some kind ...
That is a MIL-5015 style connector, used in a wide v...DaleHCook — 10:19 AM |
| I would suggest changing the topic from "P45-6365 Universal Transformer" to "45-6365 Universal IFT."...DaleHCook — 10:08 AM |
| And life just keeps getting more complicated. By dconant.
Dittos'Jimradio — 08:01 AM |
| hello david,
There are currently 1262 online users. [Complete List] » 3 Member(s) | 1259 Guest(s)
