Recapped My Predicta Tandem, I don't know what to do
Threads: 43
City: Chicago, IL
If I had to choose between those, I'd definitely go with the Hitachi. 100MHz dual channel analog scope.
It uses standard 10X scope probes. You should be able to use some cheap generic ones like this:
https://www.ebay.com/itm/324999641806?ha...Sw~JZh5DGC
Max DC voltage on the scope input is 500V so be careful. Don't go probing around the vertical output transformer or horizontal output tube.
You can get a free manual here.
https://www.allaboutcircuits.com/test-me...5a/manual/
I see it has dedicated TV-V and TV-H triggering modes. That may make examining video signals a bit easier..
(This post was last modified: 01-19-2022, 07:14 PM by Bob Andersen.)
RE: Recapped My Predicta Tandem, I don't know what to do - by Bob Andersen - 01-19-2022, 07:12 PM
| Hello Rob,
I agree with you—I have one here at my house that I need to check out. It’s way over-engineered just to make...radiorich — 11:05 AM |
My Atwater Kent 84
| Well getting around to restoring my AK84. Mike was a big part in me being able to snatch this one a few years ago. I won...462ron — 10:57 AM |
| The engine is a B&S 23 inch cast Iron holds 2 quarts of oil. The Generator is a 4 pole 1800 rpm mine was made in 195...David — 10:51 AM |
| Dale: Modified topic as suggested. It is not for a specific project. I found it in a box of stuff I recently purchased...GRG — 10:34 AM |
That looks a lot like an aircraft connector of some kind ...
That is a MIL-5015 style connector, used in a wide v...DaleHCook — 10:19 AM |
| I would suggest changing the topic from "P45-6365 Universal Transformer" to "45-6365 Universal IFT."...DaleHCook — 10:08 AM |
| And life just keeps getting more complicated. By dconant.
Dittos'Jimradio — 08:01 AM |
| hello david,
There are currently 1209 online users. [Complete List] » 4 Member(s) | 1205 Guest(s)
