Grundig Balance Control
Glad you asked, Mike. I'm working on a Grundig SO 121 U/a balance control. It's a 1960 AM FM Phonograph stereo but the radio is mono only. The balance/volume is a dual control. Center shaft is volume and works fine. Outer shaft is balance and doesn't move. Being a Grundig, the controls are pretty much sealed but I'm spraying cleaner on it. I think it's the shaft that is the culprit. The last Grundig I had was the same and it came loose with alcohol, which I will try next. Getting alcohol into the sealed control is difficult. Any suggestions or comments are appreciated.
Grundig Balance Control - by RodB - 03-19-2022, 07:28 PM
RE: Grundig Balance Control - by morzh - 03-19-2022, 08:34 PM
RE: Grundig Balance Control - by RodB - 03-20-2022, 10:11 AM
RE: Grundig Balance Control - by mikethedruid - 03-20-2022, 02:35 PM
RE: Grundig Balance Control - by morzh - 03-20-2022, 07:41 PM
RE: Grundig Balance Control - by RodB - 03-20-2022, 10:50 PM
RE: Grundig Balance Control - by RodB - 03-21-2022, 04:14 PM
RE: Grundig Balance Control - by morzh - 03-24-2022, 10:06 AM
There are currently 1602 online users. [Complete List]
» 1 Member(s) | 1601 Guest(s)
