First attempt at rewinding an oscillator coil (Phil 38-12)
Go head and switch your leads around. Another way you can check it is to measure the dc voltage from grid 1 (closest to the cathode) and the cathode. Use a VTVM or a FET meter with an input impedance of 10meg ohms. With the + on the grid and the - on the cathode if the osc is running you will see some negative voltage like a volt or 2.
Now I think I've got it!
Re: First attempt at rewinding an oscillator coil (Phil 38-1 - by 7estatdef - 05-11-2011, 09:18 PM
There are currently 2319 online users. [Complete List]
» 1 Member(s) | 2318 Guest(s)
