AWA battery eliminator issue
Hi Rob,
I hear you re the 70 year old eyes. Is the B section full wave w/ center tap, half wave or bridge? Can you post the schematic?
Is this the AWA (Antique Wireless Association) W3NLB-N6GA PCB?
If so, did you install 4 diodes to make a bridge? If so, did you connect 3 wires from the transformer (connect the center tap to B-)? If you did, that is the issue. Depending on the secondary voltage of the transformer and the desired output voltage, either remove the center tap connection or the 2 diodes that are going from the B- / Center tap connection to the 2 legs of the transformer secondary.
Hope this helps.
AWA battery eliminator issue - by Rob Quay - 01-21-2023, 09:43 PM
RE: AWA battery eliminator issue - by MrFixr55 - 01-22-2023, 01:28 AM
RE: AWA battery eliminator issue - by Rob Quay - 01-22-2023, 10:39 PM
RE: AWA battery eliminator issue - by MrFixr55 - 01-24-2023, 09:16 PM
RE: AWA battery eliminator issue - by Rob Quay - 01-25-2023, 04:28 PM
RE: AWA battery eliminator issue - by MrFixr55 - 01-25-2023, 08:46 PM
RE: AWA battery eliminator issue - by MrFixr55 - 01-25-2023, 09:46 PM
RE: AWA battery eliminator issue - by Rob Quay - 01-25-2023, 10:49 PM
RE: AWA battery eliminator issue - by MrFixr55 - 01-26-2023, 08:27 AM
RE: AWA battery eliminator issue - by Rob Quay - 01-26-2023, 09:52 AM
RE: AWA battery eliminator issue - by Rob Quay - 01-26-2023, 12:56 PM
RE: AWA battery eliminator issue - by MrFixr55 - 01-26-2023, 05:43 PM
RE: AWA battery eliminator issue - by radiorich - 01-27-2023, 02:02 AM
RE: AWA battery eliminator issue - by Rob Quay - 01-27-2023, 03:33 PM
RE: AWA battery eliminator issue - by MrFixr55 - 01-27-2023, 10:12 PM
RE: AWA battery eliminator issue - by radiorich - 01-27-2023, 10:22 PM
