Atwater Kent 35
#44
Thanks John and Chas, a lot to digest here for sure! To answer your question John, yes this is the only TRF I’ve ever worked on or even listened to so I have no idea of what to expect as far as performance. My set uses all 01As except for the 200 detector. I have swapped in an 01A for the detector with not much difference. My phone line conversion to use as a long wire antenna works really well on my long wire superhet sets.
Chas, I didn’t realize these tubes/sets are that finicky as far as the “A” supply goes. I am using a computer ps that puts out 5V. I changed from a no name ps to a Dell with same voltages. The first supply I used turned out to be noisy, the Dell is much quieter. I’m going to see what I can rig up to get an honest 6-6.5V. That resistance wire in the AF filament supply was crumbling so I replaced it with a .47 ohm carbon resistor which measured close to what the wire does. I’ve tried using my signal generator by going stage by stage connecting it through a cap. Then I used a coil with several turns wound on a TP roll that fits quite well over these tubes. With the quieter ps now I can get hear 2 stations, probably 3 at night but it is alive mostly in the middle of the band, the upper and lower ends are dead. I’ve tried the AK synchronization method plus randomly experimenting.
John, I will experiment with that cap and grid resistor on the detector and see what changes occur. I have changed the B+ value up and down on the detector plate supply without much difference. So, I have lots of things to further look into and I appreciate you and Chas for all your input. OBTW, congrats John on your upcoming retirement. You obviously have antique radios as a hobby like me but in fair weather, I have my hiking and outdoor activities. Hobbies are a must otherwise you’ll be bored and go nuts, daytime TV is a wasteland! Now get yourself healed.
Ron
Philco 37-116.    Philco 70
Philco 52-944.    AK 84
Atwater Kent 35 - by 462ron - 01-19-2023, 03:46 PM
RE: Atwater Kent 35 - by mbhdesign - 01-19-2023, 10:23 PM
RE: Atwater Kent 35 - by MrFixr55 - 01-20-2023, 07:19 AM
462ron - by 462ron - 01-20-2023, 10:31 AM
RE: Atwater Kent 35 - by Radioroslyn - 01-20-2023, 10:36 AM
462ron - by 462ron - 01-20-2023, 11:07 AM
RE: Atwater Kent 35 - by mbhdesign - 01-20-2023, 11:21 AM
RE: Atwater Kent 35 - by mbhdesign - 01-20-2023, 11:35 AM
RE: Atwater Kent 35 - by Radioroslyn - 01-20-2023, 12:01 PM
RE: Atwater Kent 35 - by Radioroslyn - 01-20-2023, 01:04 PM
RE: Atwater Kent 35 - by MrFixr55 - 01-22-2023, 10:52 PM
RE: Atwater Kent 35 - by MrFixr55 - 01-22-2023, 11:15 PM
RE: Atwater Kent 35 - by Radioroslyn - 01-22-2023, 11:40 PM
462ron - by 462ron - 01-22-2023, 11:43 PM
RE: Atwater Kent 35 - by Radioroslyn - 01-23-2023, 12:23 AM
RE: Atwater Kent 35 - by MrFixr55 - 01-23-2023, 06:29 AM
462ron - by 462ron - 01-23-2023, 10:29 AM
RE: Atwater Kent 35 - by radiorich - 01-23-2023, 08:15 PM
462ron - by 462ron - 01-24-2023, 04:11 PM
RE: Atwater Kent 35 - by MrFixr55 - 01-24-2023, 05:08 PM
462ron - by 462ron - 01-24-2023, 05:59 PM
RE: Atwater Kent 35 - by MrFixr55 - 01-24-2023, 06:22 PM
462ron - by 462ron - 01-24-2023, 06:43 PM
RE: Atwater Kent 35 - by MrFixr55 - 01-24-2023, 09:50 PM
462ron - by 462ron - 01-27-2023, 02:56 PM
RE: Atwater Kent 35 - by MrFixr55 - 01-27-2023, 10:31 PM
462ron - by 462ron - 01-28-2023, 10:59 AM
RE: Atwater Kent 35 - by Chas - 01-28-2023, 12:45 PM
RE: Atwater Kent 35 - by vinzer - 01-28-2023, 01:00 PM
RE: Atwater Kent 35 - by MrFixr55 - 01-29-2023, 01:41 AM
462ron - by 462ron - 01-29-2023, 11:48 AM
RE: Atwater Kent 35 - by Ron Ramirez - 01-29-2023, 12:39 PM
462ron - by 462ron - 01-29-2023, 05:16 PM
RE: Atwater Kent 35 - by MrFixr55 - 01-29-2023, 09:12 PM
462ron - by 462ron - 01-30-2023, 10:08 AM
RE: Atwater Kent 35 - by Chas - 01-30-2023, 10:21 AM
462ron - by 462ron - 02-04-2023, 12:29 AM
RE: Atwater Kent 35 - by MrFixr55 - 02-04-2023, 12:28 PM
RE: Atwater Kent 35 - by Ron Ramirez - 02-04-2023, 04:15 PM
RE: Atwater Kent 35 - by MrFixr55 - 02-04-2023, 04:27 PM
462ron - by 462ron - 02-05-2023, 09:45 AM
RE: Atwater Kent 35 - by MrFixr55 - 02-05-2023, 01:50 PM
RE: Atwater Kent 35 - by Chas - 02-05-2023, 06:15 PM
462ron - by 462ron - 02-06-2023, 10:38 AM
RE: Atwater Kent 35 - by Chas - 02-06-2023, 11:51 AM
462ron - by 462ron - 02-06-2023, 02:20 PM
RE: Atwater Kent 35 - by Chas - 02-06-2023, 03:37 PM
462ron - by 462ron - 02-06-2023, 04:38 PM
RE: Atwater Kent 35 - by Chas - 02-06-2023, 06:06 PM
RE: Atwater Kent 35 - by Paul Philco322 - 02-06-2023, 09:13 PM
RE: Atwater Kent 35 - by MrFixr55 - 02-06-2023, 09:28 PM
RE: Atwater Kent 35 - by MrFixr55 - 02-06-2023, 09:44 PM
462ron - by 462ron - 02-16-2023, 04:25 PM
462ron - by 462ron - 02-19-2023, 01:22 PM
RE: Atwater Kent 35 - by MrFixr55 - 02-19-2023, 11:25 PM
462ron - by 462ron - 02-20-2023, 09:44 AM
RE: Atwater Kent 35 - by MrFixr55 - 02-20-2023, 01:29 PM
462ron - by 462ron - 02-21-2023, 09:40 AM
462ron - by 462ron - 02-22-2023, 09:47 AM
There are currently 2201 online users. [Complete List]
» 1 Member(s) | 2200 Guest(s)
