Philco 14 Oscillator coil rewind
Sorry to take so long to get back to you. I don't have any exact numbers for wire ga, # of turns, direction. Too bad this coil as been damaged so that you need info at is not available. Looks like you have a couple of options. Find a parts chassis or use what info you have to rewind the coil.
If you what to give an approximation a try I would go with 38ga copper wire 5' length. Wound in the same direction as the primary. If it won't oscillate all the way to the bottom of the band add a few more turns.
Now I think I've got it!
RE: Philco 14 Oscillator coil rewind - by Radioroslyn - 06-18-2023, 01:15 PM
