I prefer to tread safely with the temps.
Hot glue melting temps are 250F to 375F.
The application range for the Polypropylene material is -55 — +105C, which is up to 221F.
So, while I think that it might be OK (did it myself in the beginning without ill effects), I prefer to shield the caps from being immersed in the hot glue. Some contact through gaps in the shielding is OK.
For the same reason I put a paper wrap in the tubular caps' ends when I restuff them.
If anything, it will save you quite a bit of that hot glue
RE: Philco 90 1-47 Triode - by morzh - 06-28-2023, 12:55 PM
