6X5 tube blew out.
Thanks Arran for the reply. I have an ohmeter but can you explain how I can tell which is cathode side of socket. I assume If I ground to chassis I should not get a reading at all??
If I get a reading it would be a dead short to ground?
Also would it be wise to replace both electrolytics to tube 6X5. (exisitng are connected correctly with ground). And can I assume a regular cap even if bad would not have the ability to blow tube 6X5 on there own. Since it played well for several days before, I figuire everthing was hooked up correctly or it wouldn't played for several days. I did check wires from socket and replaced any that had cracked wire that may have been shorting out.
Bob
6X5 tube blew out. - by gennet2 - 06-22-2011, 03:03 PM
Re: 6X5 tube blew out. - by codefox1 - 06-22-2011, 04:08 PM
Re: 6X5 tube blew out. - by Arran - 06-22-2011, 06:08 PM
Re: 6X5 tube blew out. - by gennet2 - 06-23-2011, 04:08 AM
Re: 6X5 tube blew out. - by gennet2 - 06-23-2011, 04:47 PM
Re: 6X5 tube blew out. - by Arran - 06-24-2011, 12:57 AM
Re: 6X5 tube blew out. - by gennet2 - 06-24-2011, 05:10 AM
Re: 6X5 tube blew out. - by Raleigh - 06-24-2011, 10:33 AM
Re: 6X5 tube blew out. - by Arran - 06-24-2011, 11:12 PM
Re: 6X5 tube blew out. - by gennet2 - 06-26-2011, 06:26 PM
Re: 6X5 tube blew out. - by gennet2 - 06-29-2011, 06:28 AM
Re: 6X5 tube blew out. - by Ron Ramirez - 06-29-2011, 08:29 AM
Re: 6X5 tube blew out. - by Ron Ramirez - 06-29-2011, 09:27 AM
Re: 6X5 tube blew out. - by Arran - 06-29-2011, 07:26 PM
There are currently 2445 online users. [Complete List]
» 1 Member(s) | 2444 Guest(s)
