08-06-2023, 04:13 PM
Hi Tludka,
Does your signal generator have a modulator? Looking at the instructions from the 1948-49 yearbook, did Steps 2 and 3 work? Steps 2 and 3 will fail if the oscillator section of the 7A8 is not working.
If you set the signal generator to a frequency withing the broadcast band with the modulation tone on, can you receive the tone on your set? If the above is true, try another radio that uses a loop antenna (not a ferrite loop though. If the "test" set works but the one that you fixed does not, you may have a sensitivity issue. Try replacing the 7A8 if you have another laying around (unfortunately, this is not a common tube).
Do you get a lot of static, squealing, etc. on both sets, you may have the all too typical issue where the computer, smart TV, LED or CFL bulbs, etc. obliterates the AM signal.
