46-1203 No sound
The Philco library will have DATA for the model you have and any possible quirks.
How to troubleshoot a "dead" receiver as a technician would instead of "Is it this or that". Go here:
https://www.worldradiohistory.com/BOOKSH...vicing.htm
This is the repository of technical books out of print on how to service. They are generic by nature meaning not specific to a model of radio but for the techniques. You can down load as needed free. The scans are PDF word searchable. A big plus for coverage on a specific problem. The Riders series of hand books are also teaching but at a technician level.
I see that this title may be more useful:
https://www.worldradiohistory.com/BOOKSH...ellman.pdf
Highly recommended:
https://www.worldradiohistory.com/BOOKSH...y-1947.pdf
On the same main WRH page is G-E tube characteristics...
Not present or possible to PDF, I suggest getting a hard copy of most any edition of RCA's Triple-Pindex. That is a vital tool to find your way underneath any chassis.
Such as: https://www.ebay.com/itm/196354059776
A huge online tube manual can be found here:
https://frank.pocnet.net/
Franks web site works well by just typing the tube type into the browser like: 7A7 pocnet then press ENTER. You will get the tube of interest.
This is Frank's Vade Mecum: https://frank.pocnet.net/vademecum0.html
More tubes than one can possibly imagine...
If one is to continue serving receivers a useful electronic tool is a circuit tracer. This can be a restored vacuum tube unit or a solid state (battery) powered unit insulated for at least 600 volts.
I could suggest simple signal tracing but unless one realizes the risk there is a real danger of shock.
However, an RF/AF generator capacitor coupled makes a good signal injector. A salvaged amplified computer speaker protected with capacitor coupling make a good receiver tracer, create a RF probe with a diode resistor coupling. Plans for a probe are all over the web.
Where you are now seems to indicate a short or mis-wire from the volume control/phono switch forward to the speaker. Some four tubes or so and about a dozen components and a rats nest of wires. Look around for a wire snip, blob of solder shorting, component on the wrong terminal. Oh, maybe a tube in the wrong socket Icon_crazy
Be SAFE!
Chas
P.S. Beware that a DVM can tell lies about voltage and the resistance of inductors. If, you have a good VOM use it. Voltage readings printed on a schematic often have a reference text as to the resistance of the meter used to make such readings like 1000 ohms/volt. Such a meter draws a load from the circuit. A DVM draws practically nothing so it will read high and not consistently high depending on the available current from the circuit.
Pliny the younger
46-1203 No sound - by dporcaro - 06-21-2024, 01:14 AM
RE: 46-1203 No sound - by 462ron - 06-21-2024, 08:14 AM
RE: 46-1203 No sound - by dporcaro - 06-21-2024, 10:46 AM
RE: 46-1203 No sound - by morzh - 06-21-2024, 10:50 AM
RE: 46-1203 No sound - by Chas - 06-21-2024, 11:02 AM
RE: 46-1203 No sound - by dporcaro - 06-21-2024, 08:17 PM
RE: 46-1203 No sound - by morzh - 06-21-2024, 08:36 PM
RE: 46-1203 No sound - by Chas - 06-21-2024, 09:29 PM
RE: 46-1203 No sound - by 462ron - 06-22-2024, 08:09 AM
RE: 46-1203 No sound - by mancave - 06-27-2024, 06:53 AM
RE: 46-1203 No sound - by dporcaro - 07-06-2024, 12:29 AM
RE: 46-1203 No sound - by morzh - 07-06-2024, 01:45 PM
RE: 46-1203 No sound - by dporcaro - 07-07-2024, 11:15 PM
RE: 46-1203 No sound - by Chas - 07-08-2024, 08:56 AM
RE: 46-1203 No sound - by RodB - 07-08-2024, 10:28 AM
RE: 46-1203 No sound - by dporcaro - 07-10-2024, 09:31 AM
RE: 46-1203 No sound - by MrFixr55 - 07-10-2024, 05:57 PM
RE: 46-1203 No sound - by dporcaro - 07-12-2024, 01:51 PM
There are currently 1513 online users. [Complete List]
» 1 Member(s) | 1512 Guest(s)
