08-03-2024, 07:49 AM
jr, the reason you haven’t noticed any change when adjusting the primary could be maybe you have the primary directly connected to your signal generator. If that is the way your setup is, then the generator is putting a constant signal amplitude to the primary and any adjustment is getting swamped. If you put some experimental resistance in series with the generator and primary, then as you adjust things the signal is shared between the resistor and the primary and the primary impedance will vary as the frequency you chose varies. Hope this helps!
Ron
Ron
Philco 41-250. Philco49-500
GE 201. Philco 39-25
Philco 37-116. Philco 70
AK 35 Philco 46-350
Philco 60B. Majestic 50
Philco 52-944. AK 84
