Philco 66 No Plate Voltage
Before a rewire, I always make it a habit of tracing every connection and cross referencing the schematic. I will then recreate the schematic in full using CAD software (I like kiCAD, because it is free). I actually missed one tie dot myself while I was doing this for my 49-906, in the IF section. Those little dots are pesky!
In my recreated schematics, I will also add a semicircle to indicate one trace passing over top of another WITHOUT a connected node. Common practice is to do this to the horizontal trace. It’s a lot of work, but I hope it helps out the next guy to be working on my sets! I also create revisions and update parts that need to be replaced. I once needed to replace an output transformer with the closest model I could find from Hammond, for instance. Another time I needed to select a different value for a plate resistor because I couldn’t find the value called out on the Philco schematic. I got one within 10% tolerance, and marked it up on my schematic.
I realize that this is all probably overkill, but I find that it really helps me when I may go months at a time before needing to go back to the same schematic. A computerized schematic is also much more legible.
Joseph
Philco 39-750 EZ
Philco 46-480
Philco 47-1230
Philco 48-482
Philco 49-906
Philco 66 No Plate Voltage - by dconant - 10-10-2024, 03:33 PM
RE: Philco 66 No Plate Voltage - by morzh - 10-10-2024, 05:21 PM
RE: Philco 66 No Plate Voltage - by dconant - 10-10-2024, 05:31 PM
RE: Philco 66 No Plate Voltage - by morzh - 10-10-2024, 08:23 PM
RE: Philco 66 No Plate Voltage - by jrblasde - 10-12-2024, 10:12 AM
RE: Philco 66 No Plate Voltage - by dconant - 10-12-2024, 11:23 AM
RE: Philco 66 No Plate Voltage - by morzh - 10-12-2024, 02:15 PM
RE: Philco 66 No Plate Voltage - by Arran - 10-15-2024, 12:43 AM
RE: Philco 66 No Plate Voltage - by morzh - 10-15-2024, 08:51 AM
