11-28-2024, 12:51 PM
Happy Thanksgiving all!
I have made a real bonehead mistake this time. Hope someone can help. I am trying to determine where this wire in question will connect bak to when I reistall the RF unit. I had numbered it but forgot to note where I removed it from. As you'll see from the 2 attched photos(the best I could do), the wire in question is connected to pin 8 of the 6A8G and that pin is also strapped to pins 7 and 8. That wire is hard to see but it is yellow and at the very top right hand corner. While I am still a novice, I determine pin 8 as the first pin to the right of the keyway counting clockwise as viewed from the bottom. Unfortunately, I am just not sharp enough yest to determine where that wire should connect to in the chassis. It almost looks like it should go to a ground point but I am not sure.
