My first Philco radio.
I'm having a fun-tastic time uploading photos of what I'm seeing. Stand by.
The center knob, when I turned it it felt all gummy than as I was turning it popped out, the knob attached to the shaft.
It is a steel shaft with a polished ball at the end, before that is a narrowed section. When I try to push it back in I meet a springing resistance. So I am just letting it rest before I break something expensive.
I think the seller only partially recapped it. Some of them look OLD and I think he just talked new caps in parallel with the Philco block caps.
I got a spicy feeling today when I touched the chassis with it turned off. Something is breaking down.
I earthed the chassis just now and rubbed some liquid gold on the case. It looks much nicer.
I gather the mystery terminals at the back are for a proprietary Philco phonograph. I hooked a Bluetooth speaker with its speaker leads extended our of its case (I use it for fun and testing) and put music on thst terminal.
Static come out of the radio as long as audio is going in. Pause the music on my phone, I get silence on the radio. Unpause I get static.
My first Philco radio. - by Oldie Goldie - Yesterday, 08:10 AM
RE: My first Philco radio. - by jrblasde - Yesterday, 10:59 AM
RE: My first Philco radio. - by klondike98 - Yesterday, 03:27 PM
RE: My first Philco radio. - by Oldie Goldie - Yesterday, 03:51 PM
RE: My first Philco radio. - by morzh - Yesterday, 05:14 PM
RE: My first Philco radio. - by Oldie Goldie - Yesterday, 06:12 PM
RE: My first Philco radio. - by Oldie Goldie - Yesterday, 06:21 PM
RE: My first Philco radio. - by Oldie Goldie - Yesterday, 06:22 PM
RE: My first Philco radio. - by Oldie Goldie - Yesterday, 06:31 PM
RE: My first Philco radio. - by morzh - Yesterday, 08:19 PM
Custom Hammond Power Transformer
Naval jelly is a rust-removing gel containing phosphoric acid. I do not recommend using it on anything that cannot susta...DaleHCook — 08:18 AM
Thank you all for the advice. I’ll remove it from the chassis and get it cleaned up with a wire wheel. I can take it out...jrblasde — 01:21 AM
I would take the transformer out and wire wheel it FAR AWAY from the rest of the chassis. Don't need conductive Iron Ox...GarySP — 11:01 PM
Is it safe to remove rust on the transformer? It's perfectly safe to use whatever method you like on the bells/covers. I...Arran — 09:34 PM
This is the link to the schematic in our library that jrblasde was pointing you toward. Its a pdf file you can downloa...klondike98 — 08:53 PM
Still no photos. Make sure your photo file is not superlarge. Not sure, but under 1.5MB is OK. If too large, open wit...morzh — 08:19 PM
Try McMaster-Carr supply they have lots of stuff O rings and flat sheets and solid round tubing. If you had the plans fo...David — 07:54 PM
I looked at the two early and later versions of the "schematic" freely available on the internet. It's confus...Oldie Goldie — 06:31 PM
I'm having a fun-tastic time uploading photos of what I'm seeing. Stand by. The center knob, when I turned it it felt...Oldie Goldie — 06:22 PM
I'm having a fun-tastic time uploading photos of what I'm seeing. Stand by. The center knob, when I turned it it felt...Oldie Goldie — 06:21 PM
There are currently 309 online users. [Complete List]
» 2 Member(s) | 307 Guest(s)
