42-365 capacitors
Hello Tom, If this was my radio I would be using 500 volt electrolytic caps. I would not be under sizing voltage ratings. I buy my capacitors and resistors from https://www.justradios.com/ Yes the dual cap would be wired as you say. The red and green wires are the positive side and the black wire is the negative side. I noticed the dual 8 does not indicate the positive or negative side but the 10 does. Based on what Ron said the 10 should be a 12, check your schematic. I think both of your caps are previous replacements.
Dan
42-365 capacitors - by proftrussell - 01-16-2025, 12:28 AM
RE: 42-365 capacitors - by dconant - 01-16-2025, 10:28 AM
RE: 42-365 capacitors - by RodB - 01-16-2025, 11:11 AM
RE: 42-365 capacitors - by morzh - 01-16-2025, 11:26 AM
RE: 42-365 capacitors - by GarySP - 01-16-2025, 11:41 AM
RE: 42-365 capacitors - by MrFixr55 - 01-16-2025, 01:35 PM
RE: 42-365 capacitors - by klondike98 - 01-16-2025, 03:46 PM
RE: 42-365 capacitors - by radiorich - 01-21-2025, 02:25 AM
There are currently 1860 online users. [Complete List]
» 2 Member(s) | 1858 Guest(s)
