I'm going to get back into it tonight. but I disconnected the 2 main resistors off this supply going to different parts of the unit. I'm thinking maybe a diode failed?? It checks ok on my Fluke ... but maybe breaking down when higher voltage is applied?? I have a solid 220 A/C off the PT on that side, yet only around 100v or so with no load. That's with all the caps out of the circuit. BTW, I did change all the electrolytics back with my 1st revamp, so I'll change that diode tonight and clip a fresh e cap on and see that happens. It's actually about the same setup and voltages as the B+ except it's the - supply. I'll try to get a schemo posted which I have with the ICs. It's actually 2 ICs but shown as 4 on the diagram. It's really kinda weird yet ingenious how this works!
Tim
B&K 1077B no video - problem solved - by TV MAN - 02-11-2025, 01:26 PM
RE: B&K 1077B no video - by TV MAN - 02-11-2025, 02:03 PM
RE: B&K 1077B no video - by radiorich - 02-11-2025, 09:01 PM
RE: B&K 1077B no video - by TV MAN - 02-11-2025, 09:11 PM
RE: B&K 1077B no video - by radiorich - 02-11-2025, 11:07 PM
RE: B&K 1077B no video - by TV MAN - 02-12-2025, 12:41 AM
RE: B&K 1077B no video - by radiorich - 02-12-2025, 01:55 AM
RE: B&K 1077B no video - by TV MAN - 02-13-2025, 04:04 PM
RE: B&K 1077B no video - by radiorich - 02-13-2025, 10:59 PM
RE: B&K 1077B no video - by TV MAN - 02-15-2025, 12:40 AM
Technically, that's C-. B- is chassis ground. The resistor between chassis ground and the HV center tap makes the HV c...MrFixr55 — 11:24 PM
hello Roy, I’d follow Arran’s suggestion and use automotive gasket material, which I keep around for situations like th...radiorich — 10:22 PM
This might be one of those cases where it's a ground to an AC voltage and B- to DC.RodB — 08:22 PM
Really Rod? I know you would not steer me wrong but AI say this is a short circuit? What if I moved the 6 volt center ta...dconant — 06:40 PM
My Atwater Kent 84
