Hello Tim,
I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at times and go into shutdown it ended up being a bad diode in the switching powersupply and did that stump me for about year .
P.S. my Customer had given it to me !
B&K 1077B no video - problem solved - by TV MAN - 02-11-2025, 01:26 PM
RE: B&K 1077B no video - by TV MAN - 02-11-2025, 02:03 PM
RE: B&K 1077B no video - by radiorich - 02-11-2025, 09:01 PM
RE: B&K 1077B no video - by TV MAN - 02-11-2025, 09:11 PM
RE: B&K 1077B no video - by radiorich - 02-11-2025, 11:07 PM
RE: B&K 1077B no video - by TV MAN - 02-12-2025, 12:41 AM
RE: B&K 1077B no video - by radiorich - 02-12-2025, 01:55 AM
RE: B&K 1077B no video - by TV MAN - 02-13-2025, 04:04 PM
RE: B&K 1077B no video - by radiorich - 02-13-2025, 10:59 PM
RE: B&K 1077B no video - by TV MAN - 02-15-2025, 12:40 AM
Value of capacitor
If this helps you sort it out just remember 10,000 mmfd or pf = .01 mfd. So 5,000mmfd = .005 mfd.Radioroslyn — 04:23 PM
Value of capacitor
OP here- the parts list calls for an .005 1000 volt mica. It currently has an .005 1000 volt electrolytic that is at lea...bridkarl — 02:09 PM
Value of capacitor
Maybe it's one of those paper caps that is wrapped in a mica-lookiing case.RodB — 01:51 PM
Value of capacitor
I also was wondering what the post about using polarized caps had to do with the subject? The cap is 5nF, does not exis...morzh — 10:22 AM
Value of capacitor
The OP stated that there is an electrolytic in the circuit in place of the coupling cap and wondered what effect it has....RodB — 09:53 AM
Value of capacitor
According to AI... ...assuming the electrolytic that's in it now is polarized... What does your response have to ...DaleHCook — 08:17 AM
Most loop antenna setups are either one continuous loop with two connections or 2 loops with 4 connections. The latter c...RodB — 02:16 PM
Value of capacitor
Not trying to answer for the OP, just commenting on the thread. According to AI... ...assuming the electrolytic that'...HowardWoodard — 02:09 PM
Hello Keith! I've updated your thread with the proper model number. Take care, - GaryGarySP — 01:10 PM
Value of capacitor
Why are you having to replace it? Does it measure out of tolerance? Is it mechanically damaged?DaleHCook — 07:50 AM
