02-15-2025, 11:01 AM
Thank you for your replies.
That is the correct schematic and pin out diagram for the rectifier. The resistance across the power plug is 328.6 ohms.
At this point, I am getting some voltage to pass through the radio. (It is not correct, but that's another issue.) I've attached a picture of the 35Y4. It shows the key and the connection to the filament resistor. I replaced the new caps and resistors. The dark yellow wire from pin 5 to the 132-ohm end of the filament resistor is original.
The tube is a 35Y4. I believe it is the original one that Philco shipped with the radio, although the schematic shows 35Z3 because Pin 4 is connected and Pin 8 is not.
