VTVM meter moves when my hand is next to it & not on
Any metal/magnetic things IN or ON your hand?
Or it is on high sensitivity limit, and measures charge on you? Or on AC and measure somehow the signal through your capacitance?
Ok guys. Thanks for the input. As for AI this is why I ask the experts. Dandconant — 07:39 AM
Technically, that's C-. B- is chassis ground. The resistor between chassis ground and the HV center tap makes the HV c...MrFixr55 — 11:24 PM
hello Roy, I’d follow Arran’s suggestion and use automotive gasket material, which I keep around for situations like th...radiorich — 10:22 PM
This might be one of those cases where it's a ground to an AC voltage and B- to DC.RodB — 08:22 PM
Really Rod? I know you would not steer me wrong but AI say this is a short circuit? What if I moved the 6 volt center ta...dconant — 06:40 PM
There are currently 1250 online users. [Complete List]
» 2 Member(s) | 1248 Guest(s)
