Hello everyone!
I've been working on a Philco 38 farm radio with the code 121 version chassis. As you all may know this set uses a rather rare tube, the type 15 pentode as an autodyne converter. I am not deeply versed in autodyne converter circuits. I'm still a few shades green at this kind of stuff.
 To preface my work on this radio, I have recapped it and changed all of the resistors because they were out of tolerance. I did not touch any of the micas. I checked all voltages on the tubes and they are within spec. All tubes are good. I checked all coils and audio xfrmrs for continuity. They all passed. The tuning capacitor is a little
dirty but no plates are rubbing. I used the two radio method and verified the local oscillator is running. The driver and push-pull audio is working. I checked the band switch and it's good. When I touch the detector grid cap and I get a buzz. So the detector is working. When I touch the grid cap of the IF amp and I get a response, like the buzz plus static. When I touch the converter's grid cap I get static. I also touched the tuning cap stator terminal on the antenna side. That gives me static. When I take my finger off of the grid cap or the tuning cap stator, I get nothing. The antenna terminal gives no response when I touch it. It has a 4 foot length of wire with a little kit AM transmitter pumping out signal and the radio acts like it's not even there. Even though I checked the antenna coil could there still be an issue with it? Could it be the volume control? It uses the volume control to throttle the incoming signal. It's directly connected to the antenna coil. What am I missing?
 Any help would be appreciated.
Thank you.
Philco model 38 code 121 not receiving signal. - by Stormlord5500 - 04-20-2025, 06:36 PM
