08-17-2011, 07:55 AM
It is sort of original - sort of in that I see it has the Sprague name on it, so it is a replacement for the original Philco part.
This cap and coil combination was intended to act as a wave trap at the set's IF frequency, 455 kc, and to shunt stray IF currents to ground.
You can read more about it on Chuck's site.
http://www.philcorepairbench.com/tips/svctip37.htm
In replacing this part, you can either replace it with a 0.22 uF cap and not worry about the wires wrapped around it, or you can wrap a new wire around the new cap if you wish. You will see how it should be wound when you undo the original.
