I've started looking into the very weak and garbled reception in the set (I have the HS-62A version of the chassis seen in the schematic). Powering up on batteries for this set did not change the poor reception so I injected an RF modulated signal onto the grid (pin 6) of the 1R5 and checked to see what I got out at the plate (pin 2). I have a vintage Lafayette KT-208 signal generator and tracer. The tracer probe picked up the modulated tone applied to the grid but nothing at the plate (well there was a motorboating sound but it was not the modulation frequency). I took the 1R5 out and replaced it with another but got the same result. Both tubes check ok on my Jackson 648R tester.
My voltage around the 1R5 are:
Pin 6 67volts
Pin 3 37 volts
Pin 4 -3 volts
Pin 7 1.2 volts
R2 measures right at 103k ohms and pin 3 of IR5 to pin 2 of T-1 is dead on 22k ohms.
I've cleaned the tube pins and socket and do not see any misconnections. I'm thinking I must have a problem in the L-2 oscillator coil or T-1 IF transformer, neither of which is good news I think. Time to think about things...
[Image: https://www.dropbox.com/scl/fi/06vp7t5yx...4jl3&raw=1]
1949 Motorola 5A9M - by klondike98 - 05-10-2025, 01:36 AM
RE: 1949 Motorola 5A9M - by Joe Rossi - 05-16-2025, 07:56 PM
RE: 1949 Motorola 5A9M - by Arran - 05-19-2025, 12:41 AM
RE: 1949 Motorola 5A9M - by Arran - 05-20-2025, 07:48 PM
RE: 1949 Motorola 5A9M - by klondike98 - 05-22-2025, 11:49 AM
RE: 1949 Motorola 5A9M - by klondike98 - 05-22-2025, 12:22 PM
RE: 1949 Motorola 5A9M - by Arran - 05-22-2025, 02:28 PM
RE: 1949 Motorola 5A9M - by GarySP - 05-22-2025, 05:46 PM
RE: 1949 Motorola 5A9M - by klondike98 - 05-22-2025, 07:40 PM
RE: 1949 Motorola 5A9M - by Arran - 05-22-2025, 10:05 PM
RE: 1949 Motorola 5A9M - by klondike98 - 05-22-2025, 11:56 PM
RE: 1949 Motorola 5A9M - by GarySP - 05-23-2025, 12:18 PM
RE: 1949 Motorola 5A9M - by MrFixr55 - 05-23-2025, 10:15 PM
RE: 1949 Motorola 5A9M - by klondike98 - 05-24-2025, 02:25 PM
RE: 1949 Motorola 5A9M - by klondike98 - 05-24-2025, 11:47 PM
RE: 1949 Motorola 5A9M - by Arran - 05-25-2025, 01:02 AM
RE: 1949 Motorola 5A9M - by radiorich - 05-25-2025, 02:04 AM
RE: 1949 Motorola 5A9M - by klondike98 - 05-25-2025, 01:02 PM
RE: 1949 Motorola 5A9M - by klondike98 - 05-25-2025, 06:39 PM
RE: 1949 Motorola 5A9M - by RodB - 05-25-2025, 08:10 PM
RE: 1949 Motorola 5A9M - by radiorich - 05-26-2025, 12:43 AM
RE: 1949 Motorola 5A9M - by klondike98 - 05-26-2025, 12:48 AM
RE: 1949 Motorola 5A9M - by Arran - 05-26-2025, 03:44 AM
RE: 1949 Motorola 5A9M - by Arran - 05-27-2025, 02:07 AM
RE: 1949 Motorola 5A9M - by klondike98 - 05-27-2025, 10:45 AM
RE: 1949 Motorola 5A9M - by klondike98 - 05-27-2025, 11:34 AM
RE: 1949 Motorola 5A9M - by RodB - 05-27-2025, 01:54 PM
RE: 1949 Motorola 5A9M - by Vlad95 - 05-27-2025, 02:14 PM
RE: 1949 Motorola 5A9M - by klondike98 - 05-27-2025, 03:00 PM
RE: 1949 Motorola 5A9M - by klondike98 - 06-05-2025, 10:45 PM
RE: 1949 Motorola 5A9M - by RodB - 06-06-2025, 11:32 AM
RE: 1949 Motorola 5A9M - by klondike98 - 06-06-2025, 07:28 PM
RE: 1949 Motorola 5A9M - by radiorich - 06-06-2025, 08:20 PM
RE: 1949 Motorola 5A9M - by MrFixr55 - 06-06-2025, 11:24 PM
RE: 1949 Motorola 5A9M - by radiorich - 06-07-2025, 12:33 AM
RE: 1949 Motorola 5A9M - by sam - 06-07-2025, 02:12 AM
RE: 1949 Motorola 5A9M - by klondike98 - 06-07-2025, 02:07 PM
RE: 1949 Motorola 5A9M - by Paul Philco322 - 06-07-2025, 02:17 PM
RE: 1949 Motorola 5A9M - by Vlad95 - 06-07-2025, 03:50 PM
RE: 1949 Motorola 5A9M - by klondike98 - 06-11-2025, 12:00 AM
RE: 1949 Motorola 5A9M - by Arran - 06-11-2025, 12:56 AM
RE: 1949 Motorola 5A9M - by klondike98 - 06-11-2025, 03:58 AM
RE: 1949 Motorola 5A9M - by Vlad95 - 06-11-2025, 12:19 PM
RE: 1949 Motorola 5A9M - by Arran - 06-11-2025, 06:18 PM
RE: 1949 Motorola 5A9M - by Vlad95 - 06-13-2025, 02:13 PM
RE: 1949 Motorola 5A9M - by Arran - 06-13-2025, 04:54 PM
RE: 1949 Motorola 5A9M - by klondike98 - 06-13-2025, 06:54 PM
RE: 1949 Motorola 5A9M - by Vlad95 - 06-13-2025, 06:57 PM
RE: 1949 Motorola 5A9M - by Arran - 06-13-2025, 11:18 PM
RE: 1949 Motorola 5A9M - by klondike98 - 06-19-2025, 11:20 PM
RE: 1949 Motorola 5A9M - by klondike98 - 06-22-2025, 02:34 PM
RE: 1949 Motorola 5A9M - by Vlad95 - 06-22-2025, 02:42 PM
RE: 1949 Motorola 5A9M - by morzh - 06-22-2025, 03:18 PM
RE: 1949 Motorola 5A9M - by RodB - 06-22-2025, 03:44 PM
RE: 1949 Motorola 5A9M - by Vlad95 - 06-22-2025, 04:31 PM
RE: 1949 Motorola 5A9M - by klondike98 - 06-22-2025, 05:09 PM
RE: 1949 Motorola 5A9M - by klondike98 - 06-22-2025, 07:12 PM
RE: 1949 Motorola 5A9M - by morzh - 06-22-2025, 09:36 PM
RE: 1949 Motorola 5A9M - by klondike98 - 06-22-2025, 09:57 PM
RE: 1949 Motorola 5A9M - by klondike98 - 06-22-2025, 10:29 PM
RE: 1949 Motorola 5A9M - by Arran - 06-23-2025, 07:30 PM
RE: 1949 Motorola 5A9M - by klondike98 - 06-23-2025, 11:31 PM
RE: 1949 Motorola 5A9M - by RodB - 06-24-2025, 08:59 AM
RE: 1949 Motorola 5A9M - by MrFixr55 - 06-24-2025, 10:06 AM
RE: 1949 Motorola 5A9M - by klondike98 - 06-24-2025, 01:08 PM
RE: 1949 Motorola 5A9M - by Arran - 06-25-2025, 02:16 AM
RE: 1949 Motorola 5A9M - by RodB - 06-25-2025, 10:13 AM
RE: 1949 Motorola 5A9M - by MrFixr55 - 06-25-2025, 09:52 PM
RE: 1949 Motorola 5A9M - by klondike98 - 07-19-2025, 07:09 PM
RE: 1949 Motorola 5A9M - by Arran - 07-19-2025, 11:21 PM
RE: 1949 Motorola 5A9M - by klondike98 - 07-20-2025, 02:39 AM
