Threads: 55
City: Roseville, MN
The tubes are all loctal, there's no need to change that. The trouble with local tubes is corrosion on the pins and they cannot be cleaned up with water without wiping off the label. Missing labels might show up if the glass is set in a freezer for about 4 minutes, then removed. Look carefully at an angle, usually on the top, where the tube number goes and you might see the number faintly. If you do get the number have a sharpie ready to mark the base. You may have to buy tubes to replace the unknown ones. Check with Bob Dobush at findatube.com. The symptoms you're getting may be from bad contact on the tube pins; clean the sockets with Deoxit and a brass brush on the pins.
RE: Philco 42-345 Restoration/Repair - by RodB - 06-20-2025, 05:37 PM
| Hello Everyone,
