07-02-2025, 06:58 PM
One suggestion I would offer is to get a brown Sharpie permanent marker and color in the cracks to help hide after the epoxy is applied. I would get a shade or three of different brown markers to see which blend best. Use a pliable small putty knife to apply the epoxy from the inside-out. A credit card is a close second choice. Do your best to push as much glue through to the outside. You might consider wrapping a Bungie cord around it 4-5 times to put some compression on the crack. Use stand-offs on each side of the crack under the cord to keep it from gluing to the cabinet. Two dowel rods, one on each side of the crack will keep the cord out of the glue. Good luck! Take care, - Gary
