08-02-2025, 02:08 PM
Hello, I'll try not to confuse you.
Looking at the schematic # 83 multiple can electrolytics.
If you follow the wires from each terminal the 3uf cap will be connected to the primary of the audio transformer and also a 70,000 ohm resistor #89 and a 7,750 resistor #100.
If you can trace that out you will know what colors are.
The 2uf cap should be between a 10,000 #98 and a 30.000 #97 resistors.
You will have to trace the wire to respective locations. they won"t likely be close to the can terminals.
Hope this helps.
Hope this helps.
