Philco 41-226 electrolytic voltages
Electrolytic capacitors were rated in "working volts" (WV) and could take a certain amount of overvoltage.  In theory, the voltage could be more than 150, but in practice, there is a rather high voltage drop across a 35W4, 35Z5 or similar tube.  These tubes took a longer time than a 5Y3 or similar tube to heat up to full output.  I would stick with 150WV or 160WV.  I wouldn't go above 200WV
When I was young, the practice was to not use an electrolytic capacitor with a much higher working voltage value because the cap would not "form" or have the same capacity at a lower voltage than rated for.  This was a property of electrolytic capacitors, not of the paper-foil capacitors which should be replaced with caps having the highest practical voltage value.
Philco 41-226 electrolytic voltages - by bridkarl - 08-03-2025, 09:08 PM
RE: Philco 41-226 electrolytic voltages - by MrFixr55 - 08-04-2025, 07:42 AM
RE: Philco 41-226 electrolytic voltages - by RodB - 08-05-2025, 09:57 AM
