Isolated variac suggestions
462ron Wrote:  As for an isolation transformer and variac, what I’ve been using for years is an RCA Isotap II that can be found sometime on eBay
I have used that same Isotap for decades as my isolation transformer. I built my own Variac box, with metering and fusing, using a GR Variac which I had in stock. Mine has a cover marking it portable, so I can use it in the field.
Isolated variac suggestions - by bridkarl - 08-17-2025, 05:31 PM
RE: Isolated variac suggestions - by morzh - 08-17-2025, 08:32 PM
RE: Isolated variac suggestions - by bridkarl - 08-17-2025, 09:32 PM
RE: Isolated variac suggestions - by morzh - 08-18-2025, 08:03 AM
RE: Isolated variac suggestions - by TV MAN - 08-21-2025, 11:09 AM
RE: Isolated variac suggestions - by bridkarl - 08-21-2025, 11:23 AM
RE: Isolated variac suggestions - by bridkarl - 09-18-2025, 04:54 PM
RE: Isolated variac suggestions - by radiorich - 09-18-2025, 11:17 PM
RE: Isolated variac suggestions - by bridkarl - 09-19-2025, 12:20 AM
RE: Isolated variac suggestions - by radiorich - 09-19-2025, 01:35 AM
RE: Isolated variac suggestions - by bridkarl - 09-19-2025, 08:25 AM
RE: Isolated variac suggestions - by radiorich - 09-19-2025, 08:36 AM
RE: Isolated variac suggestions - by MrFixr55 - 09-19-2025, 08:38 AM
RE: Isolated variac suggestions - by bridkarl - 09-19-2025, 09:04 AM
462ron - by 462ron - 09-20-2025, 09:36 AM
RE: Isolated variac suggestions - by bridkarl - 09-20-2025, 10:39 AM
RE: Isolated variac suggestions - by MrFixr55 - 09-20-2025, 02:49 PM
RE: Isolated variac suggestions - by bridkarl - 09-20-2025, 06:22 PM
RE: Isolated variac suggestions - by DaleHCook - 09-21-2025, 08:51 AM
462ron - by 462ron - 09-21-2025, 08:55 AM
RE: Isolated variac suggestions - by DaleHCook - 09-21-2025, 09:49 AM
462ron - by 462ron - 09-21-2025, 10:19 AM
RE: Isolated variac suggestions - by radiorich - 09-21-2025, 12:42 PM
RE: Isolated variac suggestions - by DaleHCook - 09-21-2025, 06:01 PM
RE: Isolated variac suggestions - by radiorich - 09-21-2025, 10:18 PM
462ron - by 462ron - 09-22-2025, 07:55 AM
RE: Isolated variac suggestions - by MrFixr55 - 09-22-2025, 08:34 PM
462ron - by 462ron - 09-23-2025, 07:55 AM
RE: Isolated variac suggestions - by MrFixr55 - 09-23-2025, 11:20 AM
462ron - by 462ron - 09-24-2025, 07:48 AM
RE: Isolated variac suggestions - by MrFixr55 - 09-24-2025, 08:36 AM
Technically, that's C-. B- is chassis ground. The resistor between chassis ground and the HV center tap makes the HV c...MrFixr55 — 11:24 PM
hello Roy, I’d follow Arran’s suggestion and use automotive gasket material, which I keep around for situations like th...radiorich — 10:22 PM
This might be one of those cases where it's a ground to an AC voltage and B- to DC.RodB — 08:22 PM
Really Rod? I know you would not steer me wrong but AI say this is a short circuit? What if I moved the 6 volt center ta...dconant — 06:40 PM
My Atwater Kent 84
