Philco Type-024 Signal Generator
Sorry about that Dale. Did not know someone had stolen your scan. I removed it.
I had looked in the Philco library and just missed it.
Regards Mike
Philco Type-024 Signal Generator - by swarten - 11-13-2025, 09:53 AM
RE: Philco Type-024 Signal Generator - by KCMike - 11-13-2025, 01:18 PM
RE: Philco Type-024 Signal Generator - by KCMike - 11-14-2025, 10:07 AM
RE: Philco Type-024 Signal Generator - by swarten - 11-14-2025, 06:54 PM
Ok guys. Thanks for the input. As for AI this is why I ask the experts. Dandconant — 07:39 AM
Technically, that's C-. B- is chassis ground. The resistor between chassis ground and the HV center tap makes the HV c...MrFixr55 — 11:24 PM
hello Roy, I’d follow Arran’s suggestion and use automotive gasket material, which I keep around for situations like th...radiorich — 10:22 PM
This might be one of those cases where it's a ground to an AC voltage and B- to DC.RodB — 08:22 PM
Really Rod? I know you would not steer me wrong but AI say this is a short circuit? What if I moved the 6 volt center ta...dconant — 06:40 PM
