Philco 38-62 Sensitivity
This is most likely the result of poor tuning of the input path. The tuning procedure is described in detail in the document you attached in the "Tuning Compensators" section.
I also strong recommend adjusting the oscillator tuning range after the first stage of IF tuning. Compensator #8 adjusts the low-frequency range to 520 kHz, and compensator #3B adjusts the high-frequency range to 1720 kHz. After this, you can proceed to adjusting the maximum sensitivity to 1600 kHz using compensator #3A and to 580 kHz using compensator #10. Since the settings are interrelated, it is recommended to repeat the tuning process several times for both low and high frequencies to achieve the best results.
If you want to work, lie down and sleep, and everything will pass.
Philco 38-62 Sensitivity - by dconant - 12-05-2025, 06:19 PM
RE: Philco 38-62 Sensitivity - by RGK20m3 - 12-05-2025, 07:01 PM
RE: Philco 38-62 Sensitivity - by Vlad95 - 12-05-2025, 08:24 PM
RE: Philco 38-62 Sensitivity - by dconant - 12-06-2025, 08:41 AM
RE: Philco 38-62 Sensitivity - by RGK20m3 - 12-08-2025, 11:13 AM
RE: Philco 38-62 Sensitivity - by Vlad95 - 12-08-2025, 02:07 PM
There are currently 1933 online users. [Complete List]
» 1 Member(s) | 1932 Guest(s)
