Model 41-287 volume issue
Nope. I'm not finding a voltage chart so I checked the tube characteristics for the 41 tub in push-pull configuration. It says it should be -25 volts. You should check resistor 61, all 3 sections. This is probably a candohm wire wound resistor fastened to the chassis or a wirewound resistor on a form. That low grid voltage can cause higher current flow in the output tubes causing overload to the transformer primary.
Model 41-287 volume issue - by mikeyg - 12-08-2025, 01:00 PM
RE: Model 41-287 volume issue - by klondike98 - 12-08-2025, 03:11 PM
RE: Model 41-287 volume issue - by Vlad95 - 12-08-2025, 03:27 PM
RE: Model 41-287 volume issue - by RodB - 12-08-2025, 04:36 PM
RE: Model 41-287 volume issue - by KCMike - 12-08-2025, 06:23 PM
RE: Model 41-287 volume issue - by mikeyg - 12-08-2025, 07:51 PM
RE: Model 41-287 volume issue - by Arran - 12-08-2025, 10:49 PM
RE: Model 41-287 volume issue - by mikeyg - 12-09-2025, 08:07 AM
RE: Model 41-287 volume issue - by mikeyg - 12-09-2025, 01:46 PM
RE: Model 41-287 volume issue - by RodB - 12-09-2025, 02:09 PM
RE: Model 41-287 volume issue - by mikeyg - 12-09-2025, 03:11 PM
RE: Model 41-287 volume issue - by RodB - 12-09-2025, 05:10 PM
RE: Model 41-287 volume issue - by mikeyg - 12-09-2025, 07:57 PM
RE: Model 41-287 volume issue - by RodB - 12-09-2025, 10:00 PM
RE: Model 41-287 volume issue - by mikeyg - 12-10-2025, 07:03 AM
RE: Model 41-287 volume issue - by RodB - 12-10-2025, 09:56 AM
RE: Model 41-287 volume issue - by mikeyg - 12-10-2025, 10:07 AM
RE: Model 41-287 volume issue - by RodB - 12-10-2025, 11:10 AM
RE: Model 41-287 volume issue - by mikeyg - 12-10-2025, 01:14 PM
RE: Model 41-287 volume issue - by RodB - 12-10-2025, 08:07 PM
RE: Model 41-287 volume issue - by mikeyg - 12-10-2025, 08:10 PM
RE: Model 41-287 volume issue - by RodB - 12-10-2025, 08:29 PM
RE: Model 41-287 volume issue - by RodB - 12-10-2025, 08:42 PM
RE: Model 41-287 volume issue - by RodB - 12-10-2025, 08:53 PM
RE: Model 41-287 volume issue - by mikeyg - 12-11-2025, 09:20 AM
RE: Model 41-287 volume issue - by RodB - 12-11-2025, 09:42 AM
RE: Model 41-287 volume issue - by Arran - 12-11-2025, 09:45 AM
RE: Model 41-287 volume issue - by MrFixr55 - 12-11-2025, 12:39 PM
RE: Model 41-287 volume issue - by mikeyg - 12-11-2025, 01:04 PM
RE: Model 41-287 volume issue - by Vlad95 - 12-11-2025, 01:42 PM
RE: Model 41-287 volume issue - by mikeyg - 12-11-2025, 07:53 PM
RE: Model 41-287 volume issue - by RodB - 12-11-2025, 09:06 PM
RE: Model 41-287 volume issue - by Arran - 12-12-2025, 02:20 AM
RE: Model 41-287 volume issue - by RodB - 12-12-2025, 12:46 PM
RE: Model 41-287 volume issue - by Arran - 12-12-2025, 06:51 PM
RE: Model 41-287 volume issue - by RodB - 12-12-2025, 07:09 PM
RE: Model 41-287 volume issue - by mikeyg - 12-13-2025, 06:22 PM
RE: Model 41-287 volume issue - by RodB - 12-13-2025, 10:03 PM
RE: Model 41-287 volume issue - by mikeyg - 12-13-2025, 10:13 PM
RE: Model 41-287 volume issue - by RodB - 12-13-2025, 11:55 PM
RE: Model 41-287 volume issue - by mikeyg - 12-14-2025, 12:52 AM
RE: Model 41-287 volume issue - by RodB - 12-14-2025, 11:11 AM
RE: Model 41-287 volume issue - by mikeyg - 12-14-2025, 04:52 PM
RE: Model 41-287 volume issue - by RodB - 12-14-2025, 05:20 PM
RE: Model 41-287 volume issue - by mikeyg - 12-15-2025, 09:58 AM
RE: Model 41-287 volume issue - by RodB - 12-15-2025, 11:28 AM
RE: Model 41-287 volume issue - by mikeyg - 12-15-2025, 12:59 PM
RE: Model 41-287 volume issue - by RodB - 12-15-2025, 01:24 PM
