Model 41-287 volume issue
I'm putting more thought into this. If the output tubes are not conducting because the transformer is open then much less current is flowing through resistor 61 producing a lower bias voltage. If resistor 61 is OK then there's a good chance the bias will be normal when you replace the transformer. Now you can see the importance of having a dim bulb or variac.
Model 41-287 volume issue - by mikeyg - 12-08-2025, 01:00 PM
RE: Model 41-287 volume issue - by klondike98 - 12-08-2025, 03:11 PM
RE: Model 41-287 volume issue - by Vlad95 - 12-08-2025, 03:27 PM
RE: Model 41-287 volume issue - by RodB - 12-08-2025, 04:36 PM
RE: Model 41-287 volume issue - by KCMike - 12-08-2025, 06:23 PM
RE: Model 41-287 volume issue - by mikeyg - 12-08-2025, 07:51 PM
RE: Model 41-287 volume issue - by Arran - 12-08-2025, 10:49 PM
RE: Model 41-287 volume issue - by mikeyg - 12-09-2025, 08:07 AM
RE: Model 41-287 volume issue - by mikeyg - 12-09-2025, 01:46 PM
RE: Model 41-287 volume issue - by RodB - 12-09-2025, 02:09 PM
RE: Model 41-287 volume issue - by mikeyg - 12-09-2025, 03:11 PM
RE: Model 41-287 volume issue - by RodB - 12-09-2025, 05:10 PM
RE: Model 41-287 volume issue - by mikeyg - 12-09-2025, 07:57 PM
RE: Model 41-287 volume issue - by RodB - 12-09-2025, 10:00 PM
RE: Model 41-287 volume issue - by mikeyg - 12-10-2025, 07:03 AM
RE: Model 41-287 volume issue - by RodB - 12-10-2025, 09:56 AM
RE: Model 41-287 volume issue - by mikeyg - 12-10-2025, 10:07 AM
RE: Model 41-287 volume issue - by RodB - 12-10-2025, 11:10 AM
RE: Model 41-287 volume issue - by mikeyg - 12-10-2025, 01:14 PM
RE: Model 41-287 volume issue - by RodB - 12-10-2025, 08:07 PM
RE: Model 41-287 volume issue - by mikeyg - 12-10-2025, 08:10 PM
RE: Model 41-287 volume issue - by RodB - 12-10-2025, 08:29 PM
RE: Model 41-287 volume issue - by RodB - 12-10-2025, 08:42 PM
RE: Model 41-287 volume issue - by RodB - 12-10-2025, 08:53 PM
RE: Model 41-287 volume issue - by mikeyg - 12-11-2025, 09:20 AM
RE: Model 41-287 volume issue - by RodB - 12-11-2025, 09:42 AM
RE: Model 41-287 volume issue - by Arran - 12-11-2025, 09:45 AM
RE: Model 41-287 volume issue - by MrFixr55 - 12-11-2025, 12:39 PM
RE: Model 41-287 volume issue - by mikeyg - 12-11-2025, 01:04 PM
RE: Model 41-287 volume issue - by Vlad95 - 12-11-2025, 01:42 PM
RE: Model 41-287 volume issue - by mikeyg - 12-11-2025, 07:53 PM
RE: Model 41-287 volume issue - by RodB - 12-11-2025, 09:06 PM
RE: Model 41-287 volume issue - by Arran - 12-12-2025, 02:20 AM
RE: Model 41-287 volume issue - by RodB - 12-12-2025, 12:46 PM
RE: Model 41-287 volume issue - by Arran - 12-12-2025, 06:51 PM
RE: Model 41-287 volume issue - by RodB - 12-12-2025, 07:09 PM
RE: Model 41-287 volume issue - by mikeyg - 12-13-2025, 06:22 PM
RE: Model 41-287 volume issue - by RodB - 12-13-2025, 10:03 PM
RE: Model 41-287 volume issue - by mikeyg - 12-13-2025, 10:13 PM
RE: Model 41-287 volume issue - by RodB - 12-13-2025, 11:55 PM
RE: Model 41-287 volume issue - by mikeyg - 12-14-2025, 12:52 AM
RE: Model 41-287 volume issue - by RodB - 12-14-2025, 11:11 AM
RE: Model 41-287 volume issue - by mikeyg - 12-14-2025, 04:52 PM
RE: Model 41-287 volume issue - by RodB - 12-14-2025, 05:20 PM
RE: Model 41-287 volume issue - by mikeyg - 12-15-2025, 09:58 AM
RE: Model 41-287 volume issue - by RodB - 12-15-2025, 11:28 AM
RE: Model 41-287 volume issue - by mikeyg - 12-15-2025, 12:59 PM
RE: Model 41-287 volume issue - by RodB - 12-15-2025, 01:24 PM
