Model 41-287 volume issue
#35
Rob;
The specs I found give the plate current as 32 ma at 250 vdc, and the screen grid at 10 ma, at 100 vdc the plate is 9 ma, and the screen 3 ma, so the 180 vdc B+ volts for B+ was obviously chosen to get the maximum performance they could out of an #84/6X5 based power supply without blowing it up. https://frank.yueksel.org/sheets/155/6/6K6G.pdf This was from a Brimar tube manual which was a division of ITT over in Britain. Unfortunately it doesn't give a push pull rating.
Another trick Philco did was to use loctals with 150 ma heaters in them, the same as what they used in their AC/DC sets, that likely reduced the burden on their power supply as well, at least the heater winding. I must say that they did a good job, unlike the contemporary Brand Z models of that era most of the Philcos I encountered still have their original power transformers.
Model 41-287 volume issue - by mikeyg - 12-08-2025, 01:00 PM
RE: Model 41-287 volume issue - by klondike98 - 12-08-2025, 03:11 PM
RE: Model 41-287 volume issue - by Vlad95 - 12-08-2025, 03:27 PM
RE: Model 41-287 volume issue - by RodB - 12-08-2025, 04:36 PM
RE: Model 41-287 volume issue - by KCMike - 12-08-2025, 06:23 PM
RE: Model 41-287 volume issue - by mikeyg - 12-08-2025, 07:51 PM
RE: Model 41-287 volume issue - by Arran - 12-08-2025, 10:49 PM
RE: Model 41-287 volume issue - by mikeyg - 12-09-2025, 08:07 AM
RE: Model 41-287 volume issue - by mikeyg - 12-09-2025, 01:46 PM
RE: Model 41-287 volume issue - by RodB - 12-09-2025, 02:09 PM
RE: Model 41-287 volume issue - by mikeyg - 12-09-2025, 03:11 PM
RE: Model 41-287 volume issue - by RodB - 12-09-2025, 05:10 PM
RE: Model 41-287 volume issue - by mikeyg - 12-09-2025, 07:57 PM
RE: Model 41-287 volume issue - by RodB - 12-09-2025, 10:00 PM
RE: Model 41-287 volume issue - by mikeyg - 12-10-2025, 07:03 AM
RE: Model 41-287 volume issue - by RodB - 12-10-2025, 09:56 AM
RE: Model 41-287 volume issue - by mikeyg - 12-10-2025, 10:07 AM
RE: Model 41-287 volume issue - by RodB - 12-10-2025, 11:10 AM
RE: Model 41-287 volume issue - by mikeyg - 12-10-2025, 01:14 PM
RE: Model 41-287 volume issue - by RodB - 12-10-2025, 08:07 PM
RE: Model 41-287 volume issue - by mikeyg - 12-10-2025, 08:10 PM
RE: Model 41-287 volume issue - by RodB - 12-10-2025, 08:29 PM
RE: Model 41-287 volume issue - by RodB - 12-10-2025, 08:42 PM
RE: Model 41-287 volume issue - by RodB - 12-10-2025, 08:53 PM
RE: Model 41-287 volume issue - by mikeyg - 12-11-2025, 09:20 AM
RE: Model 41-287 volume issue - by RodB - 12-11-2025, 09:42 AM
RE: Model 41-287 volume issue - by Arran - 12-11-2025, 09:45 AM
RE: Model 41-287 volume issue - by MrFixr55 - 12-11-2025, 12:39 PM
RE: Model 41-287 volume issue - by mikeyg - 12-11-2025, 01:04 PM
RE: Model 41-287 volume issue - by Vlad95 - 12-11-2025, 01:42 PM
RE: Model 41-287 volume issue - by mikeyg - 12-11-2025, 07:53 PM
RE: Model 41-287 volume issue - by RodB - 12-11-2025, 09:06 PM
RE: Model 41-287 volume issue - by Arran - 12-12-2025, 02:20 AM
RE: Model 41-287 volume issue - by RodB - 12-12-2025, 12:46 PM
RE: Model 41-287 volume issue - by Arran - 12-12-2025, 06:51 PM
RE: Model 41-287 volume issue - by RodB - 12-12-2025, 07:09 PM
RE: Model 41-287 volume issue - by mikeyg - 12-13-2025, 06:22 PM
RE: Model 41-287 volume issue - by RodB - 12-13-2025, 10:03 PM
RE: Model 41-287 volume issue - by mikeyg - 12-13-2025, 10:13 PM
RE: Model 41-287 volume issue - by RodB - 12-13-2025, 11:55 PM
RE: Model 41-287 volume issue - by mikeyg - 12-14-2025, 12:52 AM
RE: Model 41-287 volume issue - by RodB - 12-14-2025, 11:11 AM
RE: Model 41-287 volume issue - by mikeyg - 12-14-2025, 04:52 PM
RE: Model 41-287 volume issue - by RodB - 12-14-2025, 05:20 PM
RE: Model 41-287 volume issue - by mikeyg - 12-15-2025, 09:58 AM
RE: Model 41-287 volume issue - by RodB - 12-15-2025, 11:28 AM
RE: Model 41-287 volume issue - by mikeyg - 12-15-2025, 12:59 PM
RE: Model 41-287 volume issue - by RodB - 12-15-2025, 01:24 PM
