12-13-2025, 12:55 PM
Hello, I have decided to continue on with this radio. I am going to scrap the original speaker and output transformer. I don't know what to get from Hammond for the output transformer. I will be using a permanent magnet speaker. I hope to be able to get the field coil frame out enough to use it. I would appreciate it if someone would recommend an appropriate transformer. Would one of the listed below work?
Also MrFixr55 says I can use a 10K pot across the antenna terminals. I assume he is saying a single winding pot. If so what do I do about the other winding? Not sure how to wire the pot so advice on this would be appreciated.
Thank you,
Dan
Thank you,
Dan
