Working on a GE Radio Phonograph Combination 118
Hi Toucan,
Yes, this appears to be a 78 RPM only changer.
I can't tell for sure from the picture, but you should fond a "C" Clip on the ale stub that the turntable rotates on. Pull the clip out (Be careful that it does not shoot off into a parallel dimension), and you will be able to lift off the platter. You will likely find that the capstan (the rubber-tired wheel, turned by the motor, which in turn rotates the turntable) has either is seized due to dried grease, is missing the spring that pulls it in contact with the motor and turntable ore has melted.
Again, good luck with your project!
