Philco 36 660X IF trans
The 660 2nd IF transformer is unique in that it's triple tuned where most are double tuned. This is used to sharpen the selectivity. As for using a replacement you can probably retune a 455kc can up to 460kc or grab a 460kc can. The only caveat is that it needs to be either an input or interstage transformer not the output. It's designed to match a low impedance diode load not a high impedance grid. Will it work as good as the original probably not.
https://philcoradio.com/library/download...%20223.pdf
ps Service note the local oscillator adjustment for the bc band and the pol band are reversed to the chassis pictorial. Drove me nutz for a long time as I couldn't get the top end of the bcb to align because I was adjusting the pol band trimmer.
Now I think I've got it!
Philco 36 660X IF trans - by MICHAEL CHAMBERIS - 01-24-2026, 09:21 PM
RE: Philco 36 660X IF trans - by Radioroslyn - 01-25-2026, 01:34 PM
RE: Philco 36 660X IF trans - by DaleHCook - 01-26-2026, 09:31 AM
RE: Philco 36 660X IF trans - by DaleHCook - 01-26-2026, 06:34 PM
There are currently 2601 online users. [Complete List]
» 1 Member(s) | 2600 Guest(s)
