Model 20 weird volume issue
This is quite normal.
The volume pot is isolated from the chassis, and the shaft gets close (not sure if it is connected) to the resistive element which connects to antenna.
This will almost disappear once you put the knob on that shaft.
And also, when you hook up a good antenna to the set, your touch will not have the effect this strong.
Model 20 weird volume issue - by WallaceRoger - 01-25-2026, 10:53 PM
RE: Model 20 weird volume issue - by morzh - 01-25-2026, 11:02 PM
There are currently 2611 online users. [Complete List]
» 1 Member(s) | 2610 Guest(s)
