1946 Telechron 8H59 "Musalarm"
Bob;
It looks like you were using some 450 vdc caps, yep you can't restuff the original can with those. I have a lot of photoflash capacitors, technically you are not supposed to use too high of a capacity for in input filter cap, but I used 150 and 160 uf 330 vdc photoflash caps in AC/DC sets all the time and never blew up a rectifier tube. The last rectifier tube that failed in a set I had was a 35W4, ironically in a late 60s Westinghouse clock radio, and the reason it failed was because the 50C5 power output tube was loose, so it would periodically loose contact, and regain it, with a bunch of static, and I think it blew out the cathode connection in the 35W4. I seated the 50C5 in it's socket firmly, replaced the 35W4, and it was working fine up until I quit using it as a daily driver radio.
As to why most of the tubes were bad in your set, my guess is that it spent it's time in a kitchen, or garage. running 24/7, and the higher line voltage and leaky caps probably did not help. The line voltage is something you may want to address, a bigger dropper in series would the tube heaters would likely help.
1946 Telechron 8H59 "Musalarm" - by klondike98 - 01-18-2026, 08:02 PM
RE: 1946 Telechron 8H59 "Musalarm" - by morzh - 01-21-2026, 10:02 PM
RE: 1946 Telechron 8H59 "Musalarm" - by morzh - 01-21-2026, 10:15 PM
RE: 1946 Telechron 8H59 "Musalarm" - by radiorich - 01-21-2026, 10:26 PM
RE: 1946 Telechron 8H59 "Musalarm" - by MrFixr55 - 01-22-2026, 06:36 AM
RE: 1946 Telechron 8H59 "Musalarm" - by Arran - 01-22-2026, 09:22 PM
RE: 1946 Telechron 8H59 "Musalarm" - by radiorich - 01-23-2026, 12:21 AM
RE: 1946 Telechron 8H59 "Musalarm" - by Arran - 01-23-2026, 02:00 AM
RE: 1946 Telechron 8H59 "Musalarm" - by RodB - 01-23-2026, 10:50 AM
RE: 1946 Telechron 8H59 "Musalarm" - by morzh - 01-23-2026, 02:07 PM
RE: 1946 Telechron 8H59 "Musalarm" - by MrFixr55 - 01-23-2026, 03:50 PM
RE: 1946 Telechron 8H59 "Musalarm" - by morzh - 01-23-2026, 05:11 PM
RE: 1946 Telechron 8H59 "Musalarm" - by morzh - 02-01-2026, 07:22 PM
RE: 1946 Telechron 8H59 "Musalarm" - by MrFixr55 - 02-01-2026, 09:49 PM
RE: 1946 Telechron 8H59 "Musalarm" - by MrFixr55 - 02-01-2026, 10:05 PM
RE: 1946 Telechron 8H59 "Musalarm" - by morzh - 02-01-2026, 10:28 PM
RE: 1946 Telechron 8H59 "Musalarm" - by MrFixr55 - 02-01-2026, 10:48 PM
RE: 1946 Telechron 8H59 "Musalarm" - by morzh - 02-01-2026, 11:06 PM
RE: 1946 Telechron 8H59 "Musalarm" - by Arran - 02-02-2026, 03:01 AM
RE: 1946 Telechron 8H59 "Musalarm" - by Arran - 02-02-2026, 03:05 AM
RE: 1946 Telechron 8H59 "Musalarm" - by MrFixr55 - 02-02-2026, 04:55 PM
RE: 1946 Telechron 8H59 "Musalarm" - by MrFixr55 - 02-02-2026, 05:08 PM
RE: 1946 Telechron 8H59 "Musalarm" - by morzh - 02-02-2026, 05:19 PM
RE: 1946 Telechron 8H59 "Musalarm" - by Arran - 02-02-2026, 05:35 PM
RE: 1946 Telechron 8H59 "Musalarm" - by morzh - 02-02-2026, 05:52 PM
RE: 1946 Telechron 8H59 "Musalarm" - by MrFixr55 - 02-02-2026, 06:24 PM
