Philco 71 Tuning Capacitor Continuity
Thank you for your response. Makes total sense.
I performed new voltage readings after doing an alignment with the radio plugged into the wall. The wall voltage measured 122.9 VAC  when I did the readings. Incidentally, I can only get that one station at 620 with a little bit more volume. Nothing received on the top end of the dial.
I have attached my voltage readings. Not really understanding the CG-K readings. They are way off unless I'm not using the correct technique. I'm measuring from the CG cap connected to the tube on the capped tubes.
RE: Philco 71 Tuning Capacitor Continuity - by dmblackburn - 03-11-2026, 09:57 AM
