Zenith 6S254 Intermitten Reception
#34
MrFixr, I have freeze spray. Sprayed freeze spray everywhere and applied heat. I even sprayed freeze spray up in coils and heat. No change.
RodB, If you are referring to the forks I have cleaned between them and the frame with fine sandpaper.
I have disconnected the wave trap. I removed the shortwave detector compensator and wired the AM part directly. This disconnects the SW section and allows AM to continue to play. This way I can possibly ruled out those two items two items. I tried a fourth 6A8. Radio did its thing as soon as I turned on the radio after replacing the 6A8. So I guess I can rule out the 6A8. I have not taken out the band switch yet.
Zenith 6S254 Intermitten Reception - by dconant - 05-13-2026, 05:40 PM
RE: Zenith 6S254 Intermitten Reception - by Arran - 05-13-2026, 05:55 PM
RE: Zenith 6S254 Intermitten Reception - by Arran - 05-13-2026, 06:53 PM
RE: Zenith 6S254 Intermitten Reception - by morzh - 05-13-2026, 07:05 PM
RE: Zenith 6S254 Intermitten Reception - by RodB - 05-14-2026, 11:23 AM
RE: Zenith 6S254 Intermitten Reception - by RodB - 05-14-2026, 01:01 PM
RE: Zenith 6S254 Intermitten Reception - by morzh - 05-15-2026, 12:53 PM
RE: Zenith 6S254 Intermitten Reception - by RodB - 05-18-2026, 10:19 AM
RE: Zenith 6S254 Intermitten Reception - by morzh - 05-18-2026, 11:01 AM
RE: Zenith 6S254 Intermitten Reception - by RodB - 05-19-2026, 10:44 AM
RE: Zenith 6S254 Intermitten Reception - by RodB - 05-19-2026, 04:55 PM
RE: Zenith 6S254 Intermitten Reception - by morzh - 05-19-2026, 07:09 PM
RE: Zenith 6S254 Intermitten Reception - by morzh - 05-20-2026, 07:44 AM
RE: Zenith 6S254 Intermitten Reception - by RodB - 05-20-2026, 11:23 AM
RE: Zenith 6S254 Intermitten Reception - by dconant - 05-20-2026, 11:43 AM
RE: Zenith 6S254 Intermitten Reception - by morzh - 05-20-2026, 08:12 PM
RE: Zenith 6S254 Intermitten Reception - by Arran - 05-21-2026, 12:45 AM
RE: Zenith 6S254 Intermitten Reception - by morzh - 05-21-2026, 09:26 AM
RE: Zenith 6S254 Intermitten Reception - by RodB - 05-21-2026, 10:44 AM
RE: Zenith 6S254 Intermitten Reception - by RodB - 05-21-2026, 10:50 AM
RE: Zenith 6S254 Intermitten Reception - by morzh - 05-21-2026, 11:50 AM
RE: Zenith 6S254 Intermitten Reception - by RodB - 05-21-2026, 12:10 PM
RE: Zenith 6S254 Intermitten Reception - by RodB - 05-21-2026, 01:17 PM
RE: Zenith 6S254 Intermitten Reception - by morzh - 05-21-2026, 01:21 PM
RE: Zenith 6S254 Intermitten Reception - by RodB - 05-21-2026, 01:32 PM
RE: Zenith 6S254 Intermitten Reception - by RodB - 05-21-2026, 01:44 PM
RE: Zenith 6S254 Intermitten Reception - by morzh - 05-21-2026, 01:47 PM
RE: Zenith 6S254 Intermitten Reception - by morzh - 05-21-2026, 01:50 PM
RE: Zenith 6S254 Intermitten Reception - by morzh - 05-21-2026, 02:04 PM
RE: Zenith 6S254 Intermitten Reception - by morzh - 05-21-2026, 02:17 PM
RE: Zenith 6S254 Intermitten Reception - by RodB - 05-21-2026, 04:38 PM
RE: Zenith 6S254 Intermitten Reception - by morzh - 05-21-2026, 08:26 PM
RE: Zenith 6S254 Intermitten Reception - by morzh - 05-22-2026, 09:23 AM
RE: Zenith 6S254 Intermitten Reception - by morzh - 05-22-2026, 02:27 PM
RE: Zenith 6S254 Intermitten Reception - by tbone - 05-23-2026, 10:41 AM
RE: Zenith 6S254 Intermitten Reception - by morzh - 05-23-2026, 12:29 PM
RE: Zenith 6S254 Intermitten Reception - by morzh - 05-23-2026, 12:46 PM
RE: Zenith 6S254 Intermitten Reception - by morzh - 05-23-2026, 12:54 PM
RE: Zenith 6S254 Intermitten Reception - by tbone - 05-23-2026, 01:10 PM
RE: Zenith 6S254 Intermitten Reception - by morzh - 05-23-2026, 06:26 PM
RE: Zenith 6S254 Intermitten Reception - by morzh - 05-23-2026, 06:29 PM
RE: Zenith 6S254 Intermitten Reception - by morzh - 05-23-2026, 06:54 PM
RE: Zenith 6S254 Intermitten Reception - by morzh - 05-23-2026, 07:02 PM
RE: Zenith 6S254 Intermitten Reception - by RodB - 05-23-2026, 08:45 PM
RE: Zenith 6S254 Intermitten Reception - by morzh - 05-23-2026, 09:18 PM
RE: Zenith 6S254 Intermitten Reception - by morzh - 05-24-2026, 12:02 PM
RE: Zenith 6S254 Intermitten Reception - by morzh - 05-24-2026, 12:46 PM
RE: Zenith 6S254 Intermitten Reception - by morzh - 05-24-2026, 01:37 PM
RE: Zenith 6S254 Intermitten Reception - by tbone - 05-24-2026, 02:04 PM
RE: Zenith 6S254 Intermitten Reception - by morzh - 05-24-2026, 02:10 PM
RE: Zenith 6S254 Intermitten Reception - by morzh - 05-25-2026, 09:42 AM
RE: Zenith 6S254 Intermitten Reception - by tbone - 05-25-2026, 09:47 AM
RE: Zenith 6S254 Intermitten Reception - by morzh - 05-25-2026, 10:07 AM
RE: Zenith 6S254 Intermitten Reception - by RodB - 05-25-2026, 10:19 AM
RE: Zenith 6S254 Intermitten Reception - by RodB - 05-25-2026, 10:58 AM
RE: Zenith 6S254 Intermitten Reception - by morzh - 05-25-2026, 11:33 AM
RE: Zenith 6S254 Intermitten Reception - by morzh - 05-25-2026, 11:45 AM
RE: Zenith 6S254 Intermitten Reception - by morzh - 05-25-2026, 12:48 PM
RE: Zenith 6S254 Intermitten Reception - by morzh - 05-25-2026, 01:34 PM
RE: Zenith 6S254 Intermitten Reception - by morzh - 05-25-2026, 01:38 PM
RE: Zenith 6S254 Intermitten Reception - by morzh - 05-25-2026, 07:38 PM
RE: Zenith 6S254 Intermitten Reception - by morzh - 05-27-2026, 10:27 AM
RE: Zenith 6S254 Intermitten Reception - by RodB - 05-27-2026, 11:09 AM
RE: Zenith 6S254 Intermitten Reception - by morzh - 05-27-2026, 11:24 AM
RE: Zenith 6S254 Intermitten Reception - by morzh - 05-27-2026, 01:46 PM
RE: Zenith 6S254 Intermitten Reception - by morzh - 05-27-2026, 06:35 PM
RE: Zenith 6S254 Intermitten Reception - by morzh - 05-27-2026, 08:40 PM
RE: Zenith 6S254 Intermitten Reception - by morzh - 05-28-2026, 09:52 AM
RE: Zenith 6S254 Intermitten Reception - by morzh - 05-28-2026, 10:22 AM
RE: Zenith 6S254 Intermitten Reception - by morzh - 05-28-2026, 11:07 AM
RE: Zenith 6S254 Intermitten Reception - by morzh - 05-28-2026, 02:32 PM
RE: Zenith 6S254 Intermitten Reception - by morzh - 05-28-2026, 04:25 PM
RE: Zenith 6S254 Intermitten Reception - by morzh - 05-29-2026, 10:57 AM
RE: Zenith 6S254 Intermitten Reception - by Chas - 05-29-2026, 03:33 PM
RE: Zenith 6S254 Intermitten Reception - by morzh - 05-30-2026, 09:23 AM
RE: Zenith 6S254 Intermitten Reception - by morzh - 05-31-2026, 10:12 AM
RE: Zenith 6S254 Intermitten Reception - by morzh - 05-31-2026, 11:29 AM
RE: Zenith 6S254 Intermitten Reception - by morzh - 05-31-2026, 11:31 AM
RE: Zenith 6S254 Intermitten Reception - by tbone - 05-31-2026, 12:38 PM
RE: Zenith 6S254 Intermitten Reception - by morzh - 05-31-2026, 02:31 PM
RE: Zenith 6S254 Intermitten Reception - by tbone - 05-31-2026, 04:12 PM
RE: Zenith 6S254 Intermitten Reception - by tbone - 05-31-2026, 04:28 PM
RE: Zenith 6S254 Intermitten Reception - by morzh - 06-01-2026, 11:08 AM
RE: Zenith 6S254 Intermitten Reception - by morzh - 06-01-2026, 02:21 PM
RE: Zenith 6S254 Intermitten Reception - by tbone - 06-01-2026, 03:37 PM
RE: Zenith 6S254 Intermitten Reception - by morzh - 06-01-2026, 04:17 PM
RE: Zenith 6S254 Intermitten Reception - by morzh - 06-02-2026, 08:38 AM
RE: Zenith 6S254 Intermitten Reception - by Chas - 06-02-2026, 10:09 AM
RE: Zenith 6S254 Intermitten Reception - by morzh - 06-02-2026, 10:11 AM
RE: Zenith 6S254 Intermitten Reception - by morzh - 06-02-2026, 11:16 AM
RE: Zenith 6S254 Intermitten Reception - by tbone - 06-02-2026, 11:40 AM
RE: Zenith 6S254 Intermitten Reception - by morzh - 06-02-2026, 11:52 AM
RE: Zenith 6S254 Intermitten Reception - by morzh - 06-02-2026, 12:05 PM
RE: Zenith 6S254 Intermitten Reception - by morzh - 06-02-2026, 01:10 PM
RE: Zenith 6S254 Intermitten Reception - by RodB - 06-02-2026, 02:06 PM
RE: Zenith 6S254 Intermitten Reception - by morzh - 06-02-2026, 03:45 PM
RE: Zenith 6S254 Intermitten Reception - by morzh - 06-02-2026, 06:51 PM
RE: Zenith 6S254 Intermitten Reception - by morzh - 06-03-2026, 08:50 AM
RE: Zenith 6S254 Intermitten Reception - by RodB - 06-03-2026, 09:13 AM
RE: Zenith 6S254 Intermitten Reception - by morzh - 06-03-2026, 11:28 AM
RE: Zenith 6S254 Intermitten Reception - by morzh - 06-03-2026, 01:12 PM
RE: Zenith 6S254 Intermitten Reception - by morzh - 06-03-2026, 02:41 PM
RE: Zenith 6S254 Intermitten Reception - by morzh - 06-07-2026, 12:03 PM
RE: Zenith 6S254 Intermitten Reception - by RodB - 06-07-2026, 05:05 PM
RE: Zenith 6S254 Intermitten Reception - by morzh - 06-07-2026, 06:54 PM
RE: Zenith 6S254 Intermitten Reception - by morzh - 06-08-2026, 09:15 AM
RE: Zenith 6S254 Intermitten Reception - by tbone - 06-08-2026, 12:23 PM
RE: Zenith 6S254 Intermitten Reception - by Chas - 06-08-2026, 06:24 PM
RE: Zenith 6S254 Intermitten Reception - by morzh - 06-09-2026, 09:25 AM
RE: Zenith 6S254 Intermitten Reception - by RodB - 06-09-2026, 10:24 AM
RE: Zenith 6S254 Intermitten Reception - by Chas - 06-09-2026, 11:00 AM
RE: Zenith 6S254 Intermitten Reception - by Chas - 06-10-2026, 01:30 PM
RE: Zenith 6S254 Intermitten Reception - by morzh - 06-10-2026, 02:22 PM
There are currently 2213 online users. [Complete List]
» 1 Member(s) | 2212 Guest(s)
