Thanks.
Yep, I know this article.
I even used it some 2 or more years ago to show to July McCall for her to see what the real knobs looked like, and she said she knew the McLellan guy and would ask him. I was looking for the knobs for that #1 RCA140 I have that is missing the knobs, as well as the rails and the RF cover.
But then life happened.
RE: Starting on an RCA140 - by morzh - 05-25-2026, 10:13 PM
| Ok guys. Thanks for the input. As for AI this is why I ask the experts.
Dandconant — 07:39 AM |
| Technically, that's C-. B- is chassis ground. The resistor between chassis ground and the HV center tap makes the HV c...MrFixr55 — 11:24 PM |
| hello Roy,
I’d follow Arran’s suggestion and use automotive gasket material, which I keep around for situations like th...radiorich — 10:22 PM |
| This might be one of those cases where it's a ground to an AC voltage and B- to DC.RodB — 08:22 PM |
| Really Rod? I know you would not steer me wrong but AI say this is a short circuit? What if I moved the 6 volt center ta...dconant — 06:40 PM |
| Roy;
Personally I would have left the asbestos alone if it were my set, but you can find a modern substitute that som...Arran — 04:51 PM |
| Looks like that might be the B- buss, so that would be correct.RodB — 01:32 PM |
| I noticed on the code 121 schematic the center tap for the 6 volt winding and hv winding are tied together. Is this corr...dconant — 12:16 PM |
| The Philco Parts Catalog for 1942 shows it as usable for 175 kHz, 260 kHz, and 465 kHz. The instructions will show how t...DaleHCook — 11:19 AM |
| Hello Rob,
I agree with you—I have one here at my house that I need to check out. It’s way over-engineered just to make...radiorich — 11:05 AM |
